Ana içeriğe geç
Acer Aspire TimelineX 4830T-6682 Fan Replacement
Neye ihtiyacın var
  1. Acer Aspire TimelineX 4830T-6682 Fan Replacement, Lower Back Panel: adım 1, 3 resimden 1. Acer Aspire TimelineX 4830T-6682 Fan Replacement, Lower Back Panel: adım 1, 3 resimden 2. Acer Aspire TimelineX 4830T-6682 Fan Replacement, Lower Back Panel: adım 1, 3 resimden 3.
    • Remove the single screw with a Phillips #0 screwdriver.
    • Use a plastic opening tool on the upper part of the panel to remove it and access the RAM.
    • The other way to remove the panel is by sliding it away from the laptop. The difficulty of sliding it depends on the condition of your laptop.
  2. Acer Aspire TimelineX 4830T-6682 Fan Replacement, RAM: adım 2, 3 resimden 1. Acer Aspire TimelineX 4830T-6682 Fan Replacement, RAM: adım 2, 3 resimden 2. Acer Aspire TimelineX 4830T-6682 Fan Replacement, RAM: adım 2, 3 resimden 3.
    • After the panel has been removed, locate the RAM. It should be on the lower right.
    • There are pins around the RAM that need to be pulled back. After the pins are removed, pull the RAM chip towards you to remove it.
  3. Acer Aspire TimelineX 4830T-6682 Fan Replacement, Keyboard: adım 3, 1 resimden 1.
    • Remove the eleven screws that hold that back panel to the laptop using a J0 Phillips screwdriver bit.
  4. Acer Aspire TimelineX 4830T-6682 Fan Replacement: adım 4, 3 resimden 1. Acer Aspire TimelineX 4830T-6682 Fan Replacement: adım 4, 3 resimden 2. Acer Aspire TimelineX 4830T-6682 Fan Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Place the laptop in the upright position, the lower front touchpad panel should be easily detatched at this point.
    • Remove the lower front touchpad panel by using an angled tweezers to disconnect the only wired tape connected to the motherboard.
  5. Acer Aspire TimelineX 4830T-6682 Fan Replacement: adım 5, 1 resimden 1.
    • Next, disconnect the 4 wired tapes of the keyboard from the motherboard just like we did with the lower front touchpad panel.
  6. Acer Aspire TimelineX 4830T-6682 Fan Replacement: adım 6, 2 resimden 1. Acer Aspire TimelineX 4830T-6682 Fan Replacement: adım 6, 2 resimden 2.
    • Finally, using an opening tool, gently pry along the edge of the keyboard to separate it from the laptop.
  7. Acer Aspire TimelineX 4830T-6682 Fan Replacement, Battery: adım 7, 1 resimden 1.
    • The battery will be on the side closest to the screen.
    • Gently lift it out. It will still be attached by white, red, and black wires.
  8. Acer Aspire TimelineX 4830T-6682 Fan Replacement: adım 8, 2 resimden 1. Acer Aspire TimelineX 4830T-6682 Fan Replacement: adım 8, 2 resimden 2.
    • Pull the white plug, it should easily detach.
    • Remove the battery from the device.
  9. Acer Aspire TimelineX 4830T-6682 Fan Replacement, Fan: adım 9, 1 resimden 1.
    • Remove the 3.4mm by 1.9mm screws with a Phillips #0 screwdriver from the fan's heatsink.
  10. Acer Aspire TimelineX 4830T-6682 Fan Replacement: adım 10, 1 resimden 1.
    • Remove the plastic fan dust protector
  11. Acer Aspire TimelineX 4830T-6682 Fan Replacement: adım 11, 1 resimden 1.
    • Remove the two 3.4mm by 1.9mm screws that are now exposed
  12. Acer Aspire TimelineX 4830T-6682 Fan Replacement: adım 12, 2 resimden 1. Acer Aspire TimelineX 4830T-6682 Fan Replacement: adım 12, 2 resimden 2.
    • Separate the fan from the heat sink
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jon Brunsell
592 İtibar
6 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G1, Beck Spring 2020 IUPUI, Team S1-G1, Beck Spring 2020 üyesi
IUPUI-BECK-S20S1G1
3 Üyeler
2 Yorum
Where do i get the replacement fan? Are they generic. What size do I ask for?
Daisy K - Yanıt
The fans are not generic even though the same fan might be used for several laptop models the frame of the fan might be different. A replacement fan can be purchased online by searching for the laptop model and fan. Here is an example of an Amazon search I did for the Acer Aspire 4830T fan:
https://www.amazon.com/wangpeng-Cooling-...
Best Regards
Jon Brunsell - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 661
