Ana içeriğe geç
Acer Aspire TimelineX 4830T-6682 Hard Disk Drive Replacement
Neye ihtiyacın var
  1. Acer Aspire TimelineX 4830T-6682 Hard Disk Drive Replacement, Lower Back Panel: adım 1, 3 resimden 1. Acer Aspire TimelineX 4830T-6682 Hard Disk Drive Replacement, Lower Back Panel: adım 1, 3 resimden 2. Acer Aspire TimelineX 4830T-6682 Hard Disk Drive Replacement, Lower Back Panel: adım 1, 3 resimden 3.
    • Remove the single screw with a Phillips #0 screwdriver.
    • Use a plastic opening tool on the upper part of the panel to remove it and access the RAM.
    • The other way to remove the panel is by sliding it away from the laptop. The difficulty of sliding it depends on the condition of your laptop.
  2. Acer Aspire TimelineX 4830T-6682 Hard Disk Drive Replacement, Hard Disk Drive: adım 2, 3 resimden 1. Acer Aspire TimelineX 4830T-6682 Hard Disk Drive Replacement, Hard Disk Drive: adım 2, 3 resimden 2. Acer Aspire TimelineX 4830T-6682 Hard Disk Drive Replacement, Hard Disk Drive: adım 2, 3 resimden 3.
    • Remove four silver screws, highlighted with red circles with a Phillips #1 screwdriver
    • Remove two black screws, highlighted with orange circles with a Phillips #1 screwdriver
  3. Acer Aspire TimelineX 4830T-6682 Hard Disk Drive Replacement: adım 3, 2 resimden 1. Acer Aspire TimelineX 4830T-6682 Hard Disk Drive Replacement: adım 3, 2 resimden 2.
    • Pick the hard drive up from the laptop. Keep your hand off the circuit board since the battery is still connected, and voltage might be present
    • Disconnect the SATA connector by pulling the black plastic marked in the pictures horizontally away from the hard drive
Sonuç
Jon Brunsell
592 İtibar
6 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G1, Beck Spring 2020 IUPUI, Team S1-G1, Beck Spring 2020 üyesi
IUPUI-BECK-S20S1G1
3 Üyeler
2 Yorum
Thanks for the guide. Do you know how to detach the SATA cable from the motherboard? If not, I would really appreciate your help if you know where I should look for an answer. Thanks so much for your help!!
Sasha Maleki - Yanıt
Hello,
I am glad you were able to use the guide. The connector is about two centimeters under the cover on the back side of the motherboard. The SATA cable can be removed once the motherboard is detached from the frame.
Best regards,
Jon
Jon Brunsell - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 19
Her zaman: 1,106
