Ana içeriğe geç
Acer Aspire TimelineX 4830T-6682 Keyboard Replacement
Neye ihtiyacın var
  1. Acer Aspire TimelineX 4830T-6682 Keyboard Replacement, Lower Back Panel: adım 1, 3 resimden 1. Acer Aspire TimelineX 4830T-6682 Keyboard Replacement, Lower Back Panel: adım 1, 3 resimden 2. Acer Aspire TimelineX 4830T-6682 Keyboard Replacement, Lower Back Panel: adım 1, 3 resimden 3.
    • Remove the single screw with a Phillips #0 screwdriver.
    • Use a plastic opening tool on the upper part of the panel to remove it and access the RAM.
    • The other way to remove the panel is by sliding it away from the laptop. The difficulty of sliding it depends on the condition of your laptop.
  2. Acer Aspire TimelineX 4830T-6682 Keyboard Replacement, Keyboard: adım 2, 1 resimden 1.
    • Remove the eleven screws that hold that back panel to the laptop using a J0 Phillips screwdriver bit.
  3. Acer Aspire TimelineX 4830T-6682 Keyboard Replacement: adım 3, 3 resimden 1. Acer Aspire TimelineX 4830T-6682 Keyboard Replacement: adım 3, 3 resimden 2. Acer Aspire TimelineX 4830T-6682 Keyboard Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Place the laptop in the upright position, the lower front touchpad panel should be easily detatched at this point.
    • Remove the lower front touchpad panel by using an angled tweezers to disconnect the only wired tape connected to the motherboard.
  4. Acer Aspire TimelineX 4830T-6682 Keyboard Replacement: adım 4, 1 resimden 1.
    • Next, disconnect the 4 wired tapes of the keyboard from the motherboard just like we did with the lower front touchpad panel.
  5. Acer Aspire TimelineX 4830T-6682 Keyboard Replacement: adım 5, 2 resimden 1. Acer Aspire TimelineX 4830T-6682 Keyboard Replacement: adım 5, 2 resimden 2.
    • Finally, using an opening tool, gently pry along the edge of the keyboard to separate it from the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 9
Her zaman: 1,754
