Ana içeriğe geç
Acer Aspire TimelineX 4830T-6682 RAM Replacement
Neye ihtiyacın var
  1. Acer Aspire TimelineX 4830T-6682 RAM Replacement, Lower Back Panel: adım 1, 3 resimden 1. Acer Aspire TimelineX 4830T-6682 RAM Replacement, Lower Back Panel: adım 1, 3 resimden 2. Acer Aspire TimelineX 4830T-6682 RAM Replacement, Lower Back Panel: adım 1, 3 resimden 3.
    • Remove the single screw with a Phillips #0 screwdriver.
    • Use a plastic opening tool on the upper part of the panel to remove it and access the RAM.
    • The other way to remove the panel is by sliding it away from the laptop. The difficulty of sliding it depends on the condition of your laptop.
  2. Acer Aspire TimelineX 4830T-6682 RAM Replacement, RAM: adım 2, 3 resimden 1. Acer Aspire TimelineX 4830T-6682 RAM Replacement, RAM: adım 2, 3 resimden 2. Acer Aspire TimelineX 4830T-6682 RAM Replacement, RAM: adım 2, 3 resimden 3.
    • After the panel has been removed, locate the RAM. It should be on the lower right.
    • There are pins around the RAM that need to be pulled back. After the pins are removed, pull the RAM chip towards you to remove it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 402
