Ana içeriğe geç
Acer Aspire V3-472p-324J Battery Replacement
Neye ihtiyacın var
  1. Acer Aspire V3-472p-324J Battery Replacement, Battery: adım 1, 1 resimden 1.
    • First you will flip your laptop upside down so the battery side is facing up.
  2. Acer Aspire V3-472p-324J Battery Replacement: adım 2, 1 resimden 1.
    • Once upside down, you will find the battery here.
  3. Acer Aspire V3-472p-324J Battery Replacement: adım 3, 1 resimden 1.
    • In order to access the battery you will need to remove the 18 5mm screws. Using your Phillips J1 bit remove the screws.
  4. Acer Aspire V3-472p-324J Battery Replacement: adım 4, 1 resimden 1.
    • Stand your laptop up on its side to find the seams.
  5. Acer Aspire V3-472p-324J Battery Replacement: adım 5, 1 resimden 1.
    • Carefully insert your plastic opening tool into the seam and move up and down to separate the back panel from the front. Repeat this process all around the laptop until all sides have been separated.
  6. Acer Aspire V3-472p-324J Battery Replacement: adım 6, 1 resimden 1.
    • Remove the bottom plastic panel from the top.
  7. Acer Aspire V3-472p-324J Battery Replacement: adım 7, 1 resimden 1.
    • Locate the laptop speaker connector.
  8. Acer Aspire V3-472p-324J Battery Replacement: adım 8, 1 resimden 1.
    • Gently remove the speaker connector.
  9. Acer Aspire V3-472p-324J Battery Replacement: adım 9, 1 resimden 1.
    • Once you have disconnected the speakers you will now have two separate pieces.
  10. Acer Aspire V3-472p-324J Battery Replacement: adım 10, 1 resimden 1.
    • The battery is located on the bottom panel.
  11. Acer Aspire V3-472p-324J Battery Replacement: adım 11, 1 resimden 1.
    • Use the plastic lever here and slide it to the side.
  12. Acer Aspire V3-472p-324J Battery Replacement: adım 12, 1 resimden 1.
    • While holding the plastic lever, gently separate the battery from the bottom panel of the laptop.
  13. Acer Aspire V3-472p-324J Battery Replacement: adım 13, 1 resimden 1.
    • Take the old battery and dispose per manufacturers website.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Chris Arnone
364 İtibar
1 Kılavuz yazıldı
Ekip
Gateway, Team 1-5, Kuhn Fall 2015 Gateway, Team 1-5, Kuhn Fall 2015 üyesi
GCC-KUHN-F15S1G5
1 Üye
1 Kılavuz yazıldı
2 Yorum
You don't have to remove the cover to remove the battery. Step 11 can be done with the cover on. Slide the switch over. Battery pops right out.
darren - Yanıt
Yes don’t need to take cover off -battery can be removed by using a pen/screwdriver to slide the tab to the side & battery releases.
It has a very small image of an arrow with a pen next to it. Very misleading (I tried to push it in first!)
If you wiggle the battery, you can see the battery release tab moves with it :-)
oewxiblrjrffklkifb@ttirv.net - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 3,418
