Ana içeriğe geç
Acer Aspire V3-551-8469 Fan Replacement
Neye ihtiyacın var
  1. Acer Aspire V3-551-8469 Fan Replacement, Fan: adım 1, 2 resimden 1. Acer Aspire V3-551-8469 Fan Replacement, Fan: adım 1, 2 resimden 2.
    • To release the battery, slide the orange tab to the right with a spudger.
    • The battery is now released and can be picked up and set to the side.
  2. Acer Aspire V3-551-8469 Fan Replacement: adım 2, 3 resimden 1. Acer Aspire V3-551-8469 Fan Replacement: adım 2, 3 resimden 2. Acer Aspire V3-551-8469 Fan Replacement: adım 2, 3 resimden 3.
    • Remove the 16 5.3 mm Phillips #0 screws.
    • Remove the three 3 mm Phillips #00 screws.
  3. Acer Aspire V3-551-8469 Fan Replacement: adım 3, 3 resimden 1. Acer Aspire V3-551-8469 Fan Replacement: adım 3, 3 resimden 2. Acer Aspire V3-551-8469 Fan Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Remove the back panel, and remove the white cable from the wifi chip using a pair of tweezers.
  4. Acer Aspire V3-551-8469 Fan Replacement: adım 4, 1 resimden 1.
    • Using a Phillips head #0 screwdriver, remove the four 5.3 mm screws.
  5. Acer Aspire V3-551-8469 Fan Replacement: adım 5, 3 resimden 1. Acer Aspire V3-551-8469 Fan Replacement: adım 5, 3 resimden 2. Acer Aspire V3-551-8469 Fan Replacement: adım 5, 3 resimden 3.
    • Flip the computer over and remove the touchpad cover and keyboard.
    • Be careful doing this since there are two ribbon cables connecting both panels to the motherboard.
  6. Acer Aspire V3-551-8469 Fan Replacement: adım 6, 2 resimden 1. Acer Aspire V3-551-8469 Fan Replacement: adım 6, 2 resimden 2.
    • Disconnect the four ribbon cables.
  7. Acer Aspire V3-551-8469 Fan Replacement: adım 7, 1 resimden 1.
    • Remove the five 5.3 mm Phillips #0 screws.
  8. Acer Aspire V3-551-8469 Fan Replacement: adım 8, 1 resimden 1.
    • Gently lift up the motherboard and slide it out to the right.
    • Do not force the board. If stuck, check that the ports on the left are loose, that no wires are still attached, and no screws are still in.
  9. Acer Aspire V3-551-8469 Fan Replacement: adım 9, 1 resimden 1.
    • Flip the motherboard over and using a pair of tweezers, remove the cable.
  10. Acer Aspire V3-551-8469 Fan Replacement: adım 10, 2 resimden 1. Acer Aspire V3-551-8469 Fan Replacement: adım 10, 2 resimden 2.
    • Remove the six 2mm Phillips #00 screws.
  11. Acer Aspire V3-551-8469 Fan Replacement: adım 11, 1 resimden 1.
    • Using a pair of tweezers, remove the cable.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Maritsa Garcia
800 İtibar
5 adet Kılavuz yazıldı
Ekip
Baylor, Team S1-G4, Williams Fall 2018 Baylor, Team S1-G4, Williams Fall 2018 üyesi
BU-WILLIAMS-F18S1G4
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 6
Her zaman: 650
