Ana içeriğe geç
Acer Aspire V3-551-8469 Hard Drive Replacement
Neye ihtiyacın var
  1. Acer Aspire V3-551-8469 Hard Drive Replacement, Hard Drive: adım 1, 2 resimden 1. Acer Aspire V3-551-8469 Hard Drive Replacement, Hard Drive: adım 1, 2 resimden 2.
    • To release the battery, slide the orange tab to the right with a spudger.
    • The battery is now released and can be picked up and set to the side.
  2. Acer Aspire V3-551-8469 Hard Drive Replacement: adım 2, 2 resimden 1. Acer Aspire V3-551-8469 Hard Drive Replacement: adım 2, 2 resimden 2.
    • Remove the two 5.3 mm Phillips #0 screws.
  3. Acer Aspire V3-551-8469 Hard Drive Replacement: adım 3, 2 resimden 1. Acer Aspire V3-551-8469 Hard Drive Replacement: adım 3, 2 resimden 2.
    • Pull off the back panel.
  4. Acer Aspire V3-551-8469 Hard Drive Replacement: adım 4, 1 resimden 1.
    • Pull the plastic tab on top of the hard drive.
  5. Acer Aspire V3-551-8469 Hard Drive Replacement: adım 5, 2 resimden 1. Acer Aspire V3-551-8469 Hard Drive Replacement: adım 5, 2 resimden 2.
    • Remove the four 5.3 mm screws that secure the hard drive in the frame.
Sonuç
After replacing the old hard drive, reassemble your device by following these instructions in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
Maritsa Garcia
800 İtibar
5 adet Kılavuz yazıldı
Ekip
Baylor, Team S1-G4, Williams Fall 2018 Baylor, Team S1-G4, Williams Fall 2018 üyesi
BU-WILLIAMS-F18S1G4
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 568
