Ana içeriğe geç
Acer Aspire V3-551-8469 USB Port Replacement
Neye ihtiyacın var
  1. Acer Aspire V3-551-8469 USB Port Replacement, USB Port: adım 1, 2 resimden 1. Acer Aspire V3-551-8469 USB Port Replacement, USB Port: adım 1, 2 resimden 2.
    • To release the battery, slide the orange tab to the right with a spudger.
    • The battery is now released and can be picked up and set to the side.
  2. Acer Aspire V3-551-8469 USB Port Replacement: adım 2, 2 resimden 1. Acer Aspire V3-551-8469 USB Port Replacement: adım 2, 2 resimden 2.
    • Remove the sixteen 5.3 mm Phillips #0 screws.
    • Remove the three 3 mm Phillips #00 screws.
  3. Acer Aspire V3-551-8469 USB Port Replacement: adım 3, 2 resimden 1. Acer Aspire V3-551-8469 USB Port Replacement: adım 3, 2 resimden 2.
    • Flip the computer over and remove the touchpad cover.
  4. Acer Aspire V3-551-8469 USB Port Replacement: adım 4, 1 resimden 1.
    • Remove the ribbon cable connecting the USB ports to the computer.
  5. Acer Aspire V3-551-8469 USB Port Replacement: adım 5, 1 resimden 1.
    • Using a Phillips #0 screwdriver, remove the one screw.
  6. Acer Aspire V3-551-8469 USB Port Replacement: adım 6, 1 resimden 1.
    • Slide the USB port out.
Sonuç
Maritsa Garcia
800 İtibar
5 adet Kılavuz yazıldı
Ekip
Baylor, Team S1-G4, Williams Fall 2018 Baylor, Team S1-G4, Williams Fall 2018 üyesi
BU-WILLIAMS-F18S1G4
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 215
