Ana içeriğe geç
Acer Aspire V3-551-8887 Back Panel Replacement
Neye ihtiyacın var
  1. Acer Aspire V3-551-8887 Back Panel Replacement, Back Panel: adım 1, 1 resimden 1.
    • Locate and remove the two 5.3 mm Phillips #1 screws holding the back panel in place.
  2. Acer Aspire V3-551-8887 Back Panel Replacement: adım 2, 2 resimden 1. Acer Aspire V3-551-8887 Back Panel Replacement: adım 2, 2 resimden 2.
    • Use a spudger to pry the panel up from the laptop case and remove it.
    • The laptop should now be open with the RAM and wifi chip now accessible.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jacob Lesinski
143 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 8-8, Regan Spring 2014 Cal Poly, Team 8-8, Regan Spring 2014 üyesi
CPSU-REGAN-S14S8G8
4 Üyeler
7 adet Kılavuz yazıldı
1Rehber Yorum
Is the hard drive accessible for replacement from the bottom? I see black stuff over the drive with the WIFI cables going underneath. Is that removable so one can access the drive from the bottom, or is it accessible from under the keyboard?
danwat1234 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 19
Her zaman: 1,820
