Ana içeriğe geç
Acer Aspire V3-551-8887 Motherboard Replacement
Neye ihtiyacın var
  1. Acer Aspire V3-551-8887 Motherboard Replacement, Back Panel: adım 1, 1 resimden 1.
    • Locate and remove the two 5.3 mm Phillips #1 screws holding the back panel in place.
  2. Acer Aspire V3-551-8887 Motherboard Replacement: adım 2, 2 resimden 1. Acer Aspire V3-551-8887 Motherboard Replacement: adım 2, 2 resimden 2.
    • Use a spudger to pry the panel up from the laptop case and remove it.
    • The laptop should now be open with the RAM and wifi chip now accessible.
  3. Acer Aspire V3-551-8887 Motherboard Replacement, USB Ports: adım 3, 1 resimden 1.
    • Locate the wifi chip.
  4. Acer Aspire V3-551-8887 Motherboard Replacement: adım 4, 2 resimden 1. Acer Aspire V3-551-8887 Motherboard Replacement: adım 4, 2 resimden 2.
    • Remove the 5 mm Phillips #1 screw holding the wifi chip in place.
    • Carefully remove the wifi chip.
  5. Acer Aspire V3-551-8887 Motherboard Replacement: adım 5, 1 resimden 1.
    • Remove the 8, 9 mm Phillips #1 screws holding the panel in place.
  6. Acer Aspire V3-551-8887 Motherboard Replacement: adım 6, 2 resimden 1. Acer Aspire V3-551-8887 Motherboard Replacement: adım 6, 2 resimden 2.
    • Flip the computer over, and with a spudger, remove the black panel directly below the keyboard.
    • Remove the panel and flip it up onto the keyboard
  7. Acer Aspire V3-551-8887 Motherboard Replacement: adım 7, 2 resimden 1. Acer Aspire V3-551-8887 Motherboard Replacement: adım 7, 2 resimden 2.
    • With the panel removed, locate the USB port ribbon cable connecting to the motherboard.
    • Carefully disconnect the ribbon cable.
  8. Acer Aspire V3-551-8887 Motherboard Replacement: adım 8, 1 resimden 1.
    • Unscrew the 5 mm Phillips #1 screw holding the USB ports in place.
  9. Acer Aspire V3-551-8887 Motherboard Replacement: adım 9, 1 resimden 1.
    • The USB ports can now be removed from the laptop.
  10. Acer Aspire V3-551-8887 Motherboard Replacement, Keyboard: adım 10, 1 resimden 1.
    • Flip the laptop and remove all 10 of the remaining 9mm screws from the back.
  11. Acer Aspire V3-551-8887 Motherboard Replacement: adım 11, 2 resimden 1. Acer Aspire V3-551-8887 Motherboard Replacement: adım 11, 2 resimden 2.
    • Use a spudger to gently lift the keyboard.
  12. Acer Aspire V3-551-8887 Motherboard Replacement, Motherboard: adım 12, 1 resimden 1.
    • Remove the two 10 mm Phillips #1 screws connecting the motherboard to the case.
  13. Acer Aspire V3-551-8887 Motherboard Replacement: adım 13, 1 resimden 1.
    • Disconnect the 4 ribbon cables connected to the motherboard.
    • Some ribbon cable connections may not be accessible until after beginning to lift.
  14. Acer Aspire V3-551-8887 Motherboard Replacement: adım 14, 1 resimden 1.
    • Very carefully lift the motherboard.
    • Do not force the board. If stuck, check that the ports on the left are not stuck, that no wires are still attached, and no screws are still in.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Alexander Lazar
357 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-8, Regan Spring 2014 Cal Poly, Team 8-8, Regan Spring 2014 üyesi
CPSU-REGAN-S14S8G8
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 24
Her zaman: 5,407
