Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Locate and remove the two 5.3 mm Phillips #1 screws holding the back panel in place.
Use a spudger to pry the panel up from the laptop case and remove it.
The laptop should now be open with the RAM and wifi chip now accessible.
Remove the 5 mm Phillips #1 screw holding the wifi chip in place.
Carefully remove the wifi chip.
Remove the 8, 9 mm Phillips #1 screws holding the panel in place.
Flip the computer over, and with a spudger, remove the black panel directly below the keyboard.
Remove the panel and flip it up onto the keyboard
With the panel removed, locate the USB port ribbon cable connecting to the motherboard.
Carefully disconnect the ribbon cable.
Unscrew the 5 mm Phillips #1 screw holding the USB ports in place.
7 farklı kişi bu kılavuzu tamamladı.
