Ana içeriğe geç
Acer Aspire V3-571G RAM Replacement
Neye ihtiyacın var
  1. Acer Aspire V3-571G RAM Replacement, Memory Chip (RAM): adım 1, 3 resimden 1. Acer Aspire V3-571G RAM Replacement, Memory Chip (RAM): adım 1, 3 resimden 2. Acer Aspire V3-571G RAM Replacement, Memory Chip (RAM): adım 1, 3 resimden 3.
    • Flipping your laptop over, the RAM is located on the lower half of the laptop
    • Remove the two screws shown on diagram using a Phillips #00 screwdriver
    • Use the opening tool to help lift and remove the lower case
  2. Acer Aspire V3-571G RAM Replacement: adım 2, 2 resimden 1. Acer Aspire V3-571G RAM Replacement: adım 2, 2 resimden 2.
    • Remove the screw that is securing the RAM chip in place
  3. Acer Aspire V3-571G RAM Replacement: adım 3, 2 resimden 1. Acer Aspire V3-571G RAM Replacement: adım 3, 2 resimden 2.
    • After removing the screw, push the tabs on the sides of the cards out. This will allow the RAM card to pop up so you can carefully pull it out. Repeat this for the second RAM card under it.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Erica Gomes
548 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G6, Covino Spring 2018 UMass Dartmouth, Team S4-G6, Covino Spring 2018 üyesi
UMASSD-COVINO-S18S4G6
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 19
Her zaman: 1,391
