Ana içeriğe geç
Acer Aspire V3-571G Screen Replacement
Neye ihtiyacın var
  1. Acer Aspire V3-571G Screen Replacement, Battery: adım 1, 2 resimden 1. Acer Aspire V3-571G Screen Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the laptop upside down to locate the battery at the top of the laptop.
    • Use a screwdriver to shift the orange lever to the right.
  2. Acer Aspire V3-571G Screen Replacement: adım 2, 1 resimden 1.
    • While holding the lever to the right, use your fingers to lift the battery up and out of the compartment.
  3. Acer Aspire V3-571G Screen Replacement, Screen: adım 3, 2 resimden 1. Acer Aspire V3-571G Screen Replacement, Screen: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers to carefully remove the two small pieces of plastic at the bottom of the screen.
  4. Acer Aspire V3-571G Screen Replacement: adım 4, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove both screws.
  5. Acer Aspire V3-571G Screen Replacement: adım 5, 3 resimden 1. Acer Aspire V3-571G Screen Replacement: adım 5, 3 resimden 2. Acer Aspire V3-571G Screen Replacement: adım 5, 3 resimden 3.
    • Use an opening tool to carefully loosen the casing from the screen.
    • After the casing has been loosened, gently remove it with your hands.
  6. Acer Aspire V3-571G Screen Replacement: adım 6, 2 resimden 1. Acer Aspire V3-571G Screen Replacement: adım 6, 2 resimden 2.
    • Remove four screws from the screen using a Phillips #0 screwdriver.
    • Potential for device damage: When you remove the screws, the back of the screen will fall as it is no longer supported. As you remove the last screw, carefully rest it on your work station to prevent damage.
  7. Acer Aspire V3-571G Screen Replacement: adım 7, 2 resimden 1. Acer Aspire V3-571G Screen Replacement: adım 7, 2 resimden 2.
    • Use the Phillips #0 screwdriver to remove the three screws on each side of the screen.
    • Potential for device damage: Hold the screen when removing the last screw so it does not fall and damage the device.
  8. Acer Aspire V3-571G Screen Replacement: adım 8, 2 resimden 1. Acer Aspire V3-571G Screen Replacement: adım 8, 2 resimden 2.
    • Use an opening tool to carefully pull the tape up and slide the connection out of place.
    • The screen is now completely detached.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Christopher Wilson
465 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G6, Covino Spring 2018 UMass Dartmouth, Team S4-G6, Covino Spring 2018 üyesi
UMASSD-COVINO-S18S4G6
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 26
Her zaman: 3,273
