Ana içeriğe geç
Acer Aspire V3-571G Trackpad Replacement
Neye ihtiyacın var
  1. Acer Aspire V3-571G Trackpad Replacement, Trackpad: adım 1, 2 resimden 1. Acer Aspire V3-571G Trackpad Replacement, Trackpad: adım 1, 2 resimden 2.
    • Use a metal spudger to lift up and pull back the track pad
  2. Acer Aspire V3-571G Trackpad Replacement: adım 2, 3 resimden 1. Acer Aspire V3-571G Trackpad Replacement: adım 2, 3 resimden 2. Acer Aspire V3-571G Trackpad Replacement: adım 2, 3 resimden 3.
    • When you flip the track pad over, you will notice a small tape connecting the track pad to the computer
    • Disconnect the tape by gently pulling it down
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Erica Gomes
548 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G6, Covino Spring 2018 UMass Dartmouth, Team S4-G6, Covino Spring 2018 üyesi
UMASSD-COVINO-S18S4G6
3 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
Prior to starting, remove all screws from the bottom face located beneath the touch pad.
You will also need to remove the cover in the back face beneath the pad: there are also screws behind the panel holding down the touch pad.
James - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 23
Her zaman: 1,717
