Ana içeriğe geç
Acer Aspire V3-771G Hard Drive Replacement
Neye ihtiyacın var
  1. Acer Aspire V3-771G Hard Drive Replacement, Hard Drive: adım 1, 2 resimden 1. Acer Aspire V3-771G Hard Drive Replacement, Hard Drive: adım 1, 2 resimden 2.
    • Shut down the laptop.
    • Remove the power charging cord from the laptop.
  2. Acer Aspire V3-771G Hard Drive Replacement: adım 2, 3 resimden 1. Acer Aspire V3-771G Hard Drive Replacement: adım 2, 3 resimden 2. Acer Aspire V3-771G Hard Drive Replacement: adım 2, 3 resimden 3.
    • Flip the laptop over, and find the battery compartment.
    • Use your fingers to move the orange slider located just below the battery compartment to the right.
    • Do not touch the battery connectors on the battery or laptop.
    • Lift the battery up and remove from the compartment.
  3. Acer Aspire V3-771G Hard Drive Replacement: adım 3, 2 resimden 1. Acer Aspire V3-771G Hard Drive Replacement: adım 3, 2 resimden 2.
    • Using the screwdriver, remove the nine 8 mm screws from the panel on the back of the laptop.
    • Gently lift the panel up from the open slot, use the opening tools as necessary, to free the panel from the laptop.
  4. Acer Aspire V3-771G Hard Drive Replacement: adım 4, 2 resimden 1. Acer Aspire V3-771G Hard Drive Replacement: adım 4, 2 resimden 2.
    • Remove the two screws holding the hard drive sled in place.
    • While grounding yourself, gently pull the black tag straight back, not up, to free the hard drive.
  5. Acer Aspire V3-771G Hard Drive Replacement: adım 5, 3 resimden 1. Acer Aspire V3-771G Hard Drive Replacement: adım 5, 3 resimden 2. Acer Aspire V3-771G Hard Drive Replacement: adım 5, 3 resimden 3.
    • Using the screwdriver, remove the four 4 mm screws from the hard drive sled.
    • Carefully remove the hard drive. A new one may now be installed.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
David Walker
341 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 1-36, Donnelly Fall 2014 USF Tampa, Team 1-36, Donnelly Fall 2014 üyesi
USFT-DONNELLY-F14S1G36
1 Üye
1 Kılavuz yazıldı
Bir Yorum
Please pardon my inquiry. Is the same replacement can be done to Acer Aspire V3-572P-540V? Any reply will be appreciated.
b6789b - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 35
Her zaman: 13,624
