Giriş
Before doing this replacement make sure that you have a correct 2.5" hard drive to use. The original drive is a 500 GB hard drive, but any size could be used as a replacement.
Neye ihtiyacın var
Remove the nine 4mm screws with a PH0 screwdriver.
Remove the two 6mm screws with a PH0 screwdriver.
Use a plastic opening tool to pop the latch up on the ZIF connector up.
Pull out the ribbon cable to disconnect it from one side.
Remove the black isolation pad.
2 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
What would be the correct hard drive upgrade. Something to make this laptop faster mines the 500gb the processor is and dual core prossee a4-1250
