Ana içeriğe geç
Acer Aspire V5-122P-0468 Network Card Replacement
Neye ihtiyacın var
  1. Acer Aspire V5-122P-0468 Network Card Replacement, Battery: adım 1, 2 resimden 1. Acer Aspire V5-122P-0468 Network Card Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the nine 4mm screws with a PH0 screwdriver.
    • Remove the two 6mm screws with a PH0 screwdriver.
  2. Acer Aspire V5-122P-0468 Network Card Replacement: adım 2, 2 resimden 1. Acer Aspire V5-122P-0468 Network Card Replacement: adım 2, 2 resimden 2.
    • Remove the black rubber tab on the back of the computer
    • Remove the 4mm screw hidden underneath the black tab with a PH0 screwdriver.
  3. Acer Aspire V5-122P-0468 Network Card Replacement: adım 3, 2 resimden 1. Acer Aspire V5-122P-0468 Network Card Replacement: adım 3, 2 resimden 2.
    • Orient the computer upside down, with the hinges facing away from you.
    • Find the black plastic piece in the SD card slot on the right side of the computer.
    • Remove the plastic piece by sliding it out of the SD card slot.
  4. Acer Aspire V5-122P-0468 Network Card Replacement: adım 4, 3 resimden 1. Acer Aspire V5-122P-0468 Network Card Replacement: adım 4, 3 resimden 2. Acer Aspire V5-122P-0468 Network Card Replacement: adım 4, 3 resimden 3.
    • Insert a spudger at these eight locations to disengage the plastic tabs from the housing cover, and pry apart.
    • Continue around the entire perimeter of the cover with the spudger.
    • Use a spudger to pry the cover around I/O ports.
  5. Acer Aspire V5-122P-0468 Network Card Replacement: adım 5, 3 resimden 1. Acer Aspire V5-122P-0468 Network Card Replacement: adım 5, 3 resimden 2. Acer Aspire V5-122P-0468 Network Card Replacement: adım 5, 3 resimden 3.
    • Remove the two 4mm screws using a PH0 screwdriver.
    • Depress the tabs holding the battery with a spudger.
    • Disconnect the battery connector from the motherboard using a spudger.
    • Pull the battery up and away from the laptop to remove.
  6. Acer Aspire V5-122P-0468 Network Card Replacement, Network Card: adım 6, 1 resimden 1.
    • Remove the wire connector from the network card using a plastic opening tool.
  7. Acer Aspire V5-122P-0468 Network Card Replacement: adım 7, 1 resimden 1.
    • Remove the 3mm Phillips #0 screw.
  8. Acer Aspire V5-122P-0468 Network Card Replacement: adım 8, 1 resimden 1.
    • Gently slide the network card out of the motherboard connector.
Sonuç
Nat McCormick
801 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S16-G1, Boczar Spring 2018 USF Tampa, Team S16-G1, Boczar Spring 2018 üyesi
USFT-BOCZAR-S18S16G1
5 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 541
