Ana içeriğe geç
Acer Aspire V5-122P-0468 Touchpad Replacement
Neye ihtiyacın var
  1. Acer Aspire V5-122P-0468 Touchpad Replacement, Battery: adım 1, 2 resimden 1. Acer Aspire V5-122P-0468 Touchpad Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the nine 4mm screws with a PH0 screwdriver.
    • Remove the two 6mm screws with a PH0 screwdriver.
  2. Acer Aspire V5-122P-0468 Touchpad Replacement: adım 2, 2 resimden 1. Acer Aspire V5-122P-0468 Touchpad Replacement: adım 2, 2 resimden 2.
    • Remove the black rubber tab on the back of the computer
    • Remove the 4mm screw hidden underneath the black tab with a PH0 screwdriver.
  3. Acer Aspire V5-122P-0468 Touchpad Replacement: adım 3, 2 resimden 1. Acer Aspire V5-122P-0468 Touchpad Replacement: adım 3, 2 resimden 2.
    • Orient the computer upside down, with the hinges facing away from you.
    • Find the black plastic piece in the SD card slot on the right side of the computer.
    • Remove the plastic piece by sliding it out of the SD card slot.
  4. Acer Aspire V5-122P-0468 Touchpad Replacement: adım 4, 3 resimden 1. Acer Aspire V5-122P-0468 Touchpad Replacement: adım 4, 3 resimden 2. Acer Aspire V5-122P-0468 Touchpad Replacement: adım 4, 3 resimden 3.
    • Insert a spudger at these eight locations to disengage the plastic tabs from the housing cover, and pry apart.
    • Continue around the entire perimeter of the cover with the spudger.
    • Use a spudger to pry the cover around I/O ports.
  5. Acer Aspire V5-122P-0468 Touchpad Replacement: adım 5, 3 resimden 1. Acer Aspire V5-122P-0468 Touchpad Replacement: adım 5, 3 resimden 2. Acer Aspire V5-122P-0468 Touchpad Replacement: adım 5, 3 resimden 3.
    • Remove the two 4mm screws using a PH0 screwdriver.
    • Depress the tabs holding the battery with a spudger.
    • Disconnect the battery connector from the motherboard using a spudger.
    • Pull the battery up and away from the laptop to remove.
  6. Acer Aspire V5-122P-0468 Touchpad Replacement, Touchpad: adım 6, 1 resimden 1.
    • Use the spudger to pop up the latch on the ZIF connector.
    • Pull out the ribbon cable.
  7. Acer Aspire V5-122P-0468 Touchpad Replacement: adım 7, 3 resimden 1. Acer Aspire V5-122P-0468 Touchpad Replacement: adım 7, 3 resimden 2. Acer Aspire V5-122P-0468 Touchpad Replacement: adım 7, 3 resimden 3.
    • Remove the three 2mm PH #0 screws.
    • Lift the metal tape up and off of the mounting bracket.
  8. Acer Aspire V5-122P-0468 Touchpad Replacement: adım 8, 1 resimden 1.
    • Remove the metal mounting bracket from the bottom of the touchpad
  9. Acer Aspire V5-122P-0468 Touchpad Replacement: adım 9, 2 resimden 1. Acer Aspire V5-122P-0468 Touchpad Replacement: adım 9, 2 resimden 2.
    • Carefully remove the foam pad from along the top edge of touchpad using a spudger.
    • This pad can be reused.
    • Remove the four 2mm PH #0 screws.
  10. Acer Aspire V5-122P-0468 Touchpad Replacement: adım 10, 1 resimden 1.
    • Remove the touchpad from the laptop using a spudger.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nat McCormick
801 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S16-G1, Boczar Spring 2018 USF Tampa, Team S16-G1, Boczar Spring 2018 üyesi
USFT-BOCZAR-S18S16G1
5 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 24
Her zaman: 1,758
