Ana içeriğe geç
Acer Aspire V5-131-2629 Cover Replacement
Neye ihtiyacın var
  1. Acer Aspire V5-131-2629 Cover Replacement, Battery: adım 1, 1 resimden 1.
    • Carefully turn your Acer Aspire V5-131-2629 upside down, so that the battery cell is visible and nearest to you.
  2. Acer Aspire V5-131-2629 Cover Replacement: adım 2, 1 resimden 1.
    • Identify the small, oval slide switch on the left hand side of the laptop, directly above the battery.
  3. Acer Aspire V5-131-2629 Cover Replacement: adım 3, 1 resimden 1.
    • Insert an opening tool into the hole on the right side of the oval switch. Use the opening tool to slide the switch to the right.
  4. Acer Aspire V5-131-2629 Cover Replacement: adım 4, 2 resimden 1. Acer Aspire V5-131-2629 Cover Replacement: adım 4, 2 resimden 2.
    • With the switch engaged to the right, firmly pull the battery out and towards yourself, parallel to your work surface.
  5. Acer Aspire V5-131-2629 Cover Replacement, Cover: adım 5, 1 resimden 1.
    • Remove the single Phillips #0 screw from the cover on the underside of the laptop.
  6. Acer Aspire V5-131-2629 Cover Replacement: adım 6, 2 resimden 1. Acer Aspire V5-131-2629 Cover Replacement: adım 6, 2 resimden 2.
    • Remove the cover by sliding it outwards and remove it from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Aaron Almeida
551 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G3, O'Connell Fall 2019 UMass Dartmouth, Team S1-G3, O'Connell Fall 2019 üyesi
UMASSD-O'CONNELL-F19S1G3
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 557
