Giriş
This guide provides in-depth instructions on how to remove the cover on the Acer Aspire V5-131-2629
Does your computer have a cracked or broken back plate? Do you need to get inside of your computer to replace internal components? This guide details the steps needed to remove the back cover on the Acer Aspire V5 laptop. To reassemble the back cover, just retrace the steps taken to remove the back cover.
Unfortunately, the Acer website has taken down information regarding this device. However, a basic, rather informal summary of the details and specs can be found at the following link:
++Acer Aspire V5-131-2629 prices and specs++
A general disassembly tutorial of the device can be found:
++How to Disassemble the Acer Aspire V5 131++
Neye ihtiyacın var
Carefully turn your Acer Aspire V5-131-2629 upside down, so that the battery cell is visible and nearest to you.
Remove the single Phillips #0 screw from the cover on the underside of the laptop.
Bir başkası bu kılavuzu tamamladı.
