Ana içeriğe geç
Acer Aspire V5-131-2629 Screen Replacement
Neye ihtiyacın var
  1. Acer Aspire V5-131-2629 Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Carefully turn your Acer Aspire V5-131-2629 upside down, so that the battery cell is visible and nearest to you.
  2. Acer Aspire V5-131-2629 Screen Replacement: adım 2, 1 resimden 1.
    • Identify the small, oval slide switch on the left hand side of the laptop, directly above the battery.
  3. Acer Aspire V5-131-2629 Screen Replacement: adım 3, 1 resimden 1.
    • Insert an opening tool into the hole on the right side of the oval switch. Use the opening tool to slide the switch to the right.
  4. Acer Aspire V5-131-2629 Screen Replacement: adım 4, 2 resimden 1. Acer Aspire V5-131-2629 Screen Replacement: adım 4, 2 resimden 2.
    • With the switch engaged to the right, firmly pull the battery out and towards yourself, parallel to your work surface.
  5. Acer Aspire V5-131-2629 Screen Replacement, Cover: adım 5, 1 resimden 1.
    • Remove the single Phillips #0 screw from the cover on the underside of the laptop.
  6. Acer Aspire V5-131-2629 Screen Replacement: adım 6, 2 resimden 1. Acer Aspire V5-131-2629 Screen Replacement: adım 6, 2 resimden 2.
    • Remove the cover by sliding it outwards and remove it from the device.
  7. Acer Aspire V5-131-2629 Screen Replacement, Screen: adım 7, 2 resimden 1. Acer Aspire V5-131-2629 Screen Replacement, Screen: adım 7, 2 resimden 2.
    • Remove the screen bezel by lifting up the inside rim of the bezel and popping the edge out in steady upwards and outwards motions.
    • Complete this motion around the entire circumference of the bezel.
  8. Acer Aspire V5-131-2629 Screen Replacement: adım 8, 3 resimden 1. Acer Aspire V5-131-2629 Screen Replacement: adım 8, 3 resimden 2. Acer Aspire V5-131-2629 Screen Replacement: adım 8, 3 resimden 3.
    • Remove the four Phillips screws from each of the mounting tabs in the corners of the screen.
  9. Acer Aspire V5-131-2629 Screen Replacement: adım 9, 1 resimden 1.
    • Peel back the adhesive tape that runs the length of the bottom of the screen.
    • Be careful not to damage the cables which run between the tape and the screen.
  10. Acer Aspire V5-131-2629 Screen Replacement: adım 10, 1 resimden 1.
    • Using the mounting tabs at the top corners of the screen, gently lift the screen up and out and lay it flat on the keyboard.
  11. Acer Aspire V5-131-2629 Screen Replacement: adım 11, 1 resimden 1.
    • Remove the adhesive tape covering the gold-colored connector on the top left corner of the screen.
Sonuç
Aaron Almeida
551 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G3, O'Connell Fall 2019 UMass Dartmouth, Team S1-G3, O'Connell Fall 2019 üyesi
UMASSD-O'CONNELL-F19S1G3
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 14
Her zaman: 539
