Ana içeriğe geç
Acer Aspire V5-131-2680 Battery Replacement
Neye ihtiyacın var
  1. Acer Aspire V5-131-2680 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure your laptop is powered down and completely closed before proceeding.
    • Turn your laptop upside down. The stickers should be facing up.
  2. Acer Aspire V5-131-2680 Battery Replacement: adım 2, 2 resimden 1. Acer Aspire V5-131-2680 Battery Replacement: adım 2, 2 resimden 2.
    • To open the bottom compartment, put one finger underneath the laptop and firmly grab the compartment with your thumb.
    • You can also use both thumbs for more pressure.
    • Carefully slide the bottom compartment with your thumb until you feel it pop out of place.
  3. Acer Aspire V5-131-2680 Battery Replacement: adım 3, 2 resimden 1. Acer Aspire V5-131-2680 Battery Replacement: adım 3, 2 resimden 2.
    • In front of the battery, you will find a sliding flap. This is a battery-release lock.
    • Place your finger on the latch and slide the latch to open. Pull out the battery from its compartment.
    • Do not remove your finger from the latch while sliding the battery out.
    • Once the battery is out, release the latch.
Sonuç
Naomi Zaldana
147 İtibar
1 Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 6-1, Adachi Fall 2022 CSU Los Angeles, Team 6-1, Adachi Fall 2022 üyesi
CSULA-ADACHI-F22S6G1
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 15
Son 30 gün: 21
Her zaman: 285
