Ana içeriğe geç
Acer Aspire V5-131-2680 Hard Drive Replacement
  1. Acer Aspire V5-131-2680 Hard Drive Replacement, Bottom Cover: adım 1, 1 resimden 1.
    • Make sure your laptop is powered down and completely closed before proceeding.
    • Turn your laptop upside down. The stickers should be facing up.
  2. Acer Aspire V5-131-2680 Hard Drive Replacement: adım 2, 2 resimden 1. Acer Aspire V5-131-2680 Hard Drive Replacement: adım 2, 2 resimden 2.
    • To open the bottom compartment, put one finger underneath the laptop and firmly grab the compartment with your thumb.
    • You can also use both thumbs for more pressure.
    • Carefully slide the bottom compartment with your thumb until you feel it pop out of place.
  3. Acer Aspire V5-131-2680 Hard Drive Replacement, Hard Drive: adım 3, 2 resimden 1. Acer Aspire V5-131-2680 Hard Drive Replacement, Hard Drive: adım 3, 2 resimden 2.
    • On the sides of the hard drive, you will see two side tabs. This is what holds the hard drive in place.
    • Place your finger on the left tab and press on it to loosen the hard drive.
    • After the hard drive is loose, slide it out of the compartment.
    • Do not remove your finger from the side tab while removing the hard drive.
  4. Acer Aspire V5-131-2680 Hard Drive Replacement: adım 4, 1 resimden 1.
    • You have successfully removed the hard drive from the laptop.
Sonuç
Mauricio Moreno
601 İtibar
5 adet Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 6-1, Adachi Fall 2022 CSU Los Angeles, Team 6-1, Adachi Fall 2022 üyesi
CSULA-ADACHI-F22S6G1
4 Üyeler
6 adet Kılavuz yazıldı
0 Guide Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 8
Her zaman: 218
