Ana içeriğe geç
Acer Aspire V5-473P-5602 Keyboard Replacement
Neye ihtiyacın var
  1. Acer Aspire V5-473P-5602 Keyboard Replacement, Back Panel: adım 1, 2 resimden 1. Acer Aspire V5-473P-5602 Keyboard Replacement, Back Panel: adım 1, 2 resimden 2.
    • Flip the laptop over so the back panel is facing upwards.
    • Use the Phillips #0 screwdriver to remove seventeen 2.5mm screws.
    • Remove the back panel from the laptop using an iFixit opening tool.
  2. Acer Aspire V5-473P-5602 Keyboard Replacement, Battery: adım 2, 2 resimden 1. Acer Aspire V5-473P-5602 Keyboard Replacement, Battery: adım 2, 2 resimden 2.
    • Remove the Phillips #0 screw from the middle of the battery.
  3. Acer Aspire V5-473P-5602 Keyboard Replacement: adım 3, 1 resimden 1.
    • Unplug the battery from the motherboard.
  4. Acer Aspire V5-473P-5602 Keyboard Replacement: adım 4, 1 resimden 1.
    • Carefully take the battery out of the device.
  5. Acer Aspire V5-473P-5602 Keyboard Replacement, Hard Drive: adım 5, 1 resimden 1.
    • Remove the four Phillips #0 screws from the hard drive.
  6. Acer Aspire V5-473P-5602 Keyboard Replacement: adım 6, 1 resimden 1.
    • Gently unplug the hard drive connector.
  7. Acer Aspire V5-473P-5602 Keyboard Replacement: adım 7, 1 resimden 1.
    • Remove the hard drive from the laptop.
  8. Acer Aspire V5-473P-5602 Keyboard Replacement, Fan: adım 8, 2 resimden 1. Acer Aspire V5-473P-5602 Keyboard Replacement, Fan: adım 8, 2 resimden 2.
    • Remove the five Phillips #0 screws that are holding the fan down to the base.
  9. Acer Aspire V5-473P-5602 Keyboard Replacement: adım 9, 2 resimden 1. Acer Aspire V5-473P-5602 Keyboard Replacement: adım 9, 2 resimden 2.
    • Gently unplug the cables from the Wi-Fi card.
  10. Acer Aspire V5-473P-5602 Keyboard Replacement: adım 10, 1 resimden 1.
    • Remove the fan from the laptop.
  11. Acer Aspire V5-473P-5602 Keyboard Replacement, Secondary Cooling Fan: adım 11, 2 resimden 1. Acer Aspire V5-473P-5602 Keyboard Replacement, Secondary Cooling Fan: adım 11, 2 resimden 2.
    • Unplug the cable that connects to the fan to motherboard.
  12. Acer Aspire V5-473P-5602 Keyboard Replacement: adım 12, 1 resimden 1.
    • Remove the two Phillips #0 screws that secure the fan to the base.
  13. Acer Aspire V5-473P-5602 Keyboard Replacement, Motherboard: adım 13, 2 resimden 1. Acer Aspire V5-473P-5602 Keyboard Replacement, Motherboard: adım 13, 2 resimden 2.
    • Remove the ten Phillips #0 screws that attach the motherboard to the keyboard.
  14. Acer Aspire V5-473P-5602 Keyboard Replacement: adım 14, 3 resimden 1. Acer Aspire V5-473P-5602 Keyboard Replacement: adım 14, 3 resimden 2. Acer Aspire V5-473P-5602 Keyboard Replacement: adım 14, 3 resimden 3.
    • Unplug the two data cables that attach the keyboard to the motherboard.
    • Remove the motherboard from the laptop.
  15. Acer Aspire V5-473P-5602 Keyboard Replacement, Keyboard: adım 15, 1 resimden 1.
    • Pull the clear plastic sheet from the top of the metal upper part of the keyboard.
  16. Acer Aspire V5-473P-5602 Keyboard Replacement: adım 16, 2 resimden 1. Acer Aspire V5-473P-5602 Keyboard Replacement: adım 16, 2 resimden 2.
    • Detach the keyboard clips using an iFixit opening tool.
  17. Acer Aspire V5-473P-5602 Keyboard Replacement: adım 17, 1 resimden 1.
    • Remove the keyboard from the laptop.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Noora Al-loos
283 İtibar
2 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 21
Her zaman: 1,082
