Ana içeriğe geç
Acer Aspire V5-473P-5602 Motherboard Replacement
Neye ihtiyacın var
  1. Acer Aspire V5-473P-5602 Motherboard Replacement, Back Panel: adım 1, 2 resimden 1. Acer Aspire V5-473P-5602 Motherboard Replacement, Back Panel: adım 1, 2 resimden 2.
    • Flip the laptop over so the back panel is facing upwards.
    • Use the Phillips #0 screwdriver to remove seventeen 2.5mm screws.
    • Remove the back panel from the laptop using an iFixit opening tool.
  2. Acer Aspire V5-473P-5602 Motherboard Replacement, Battery: adım 2, 2 resimden 1. Acer Aspire V5-473P-5602 Motherboard Replacement, Battery: adım 2, 2 resimden 2.
    • Remove the Phillips #0 screw from the middle of the battery.
  3. Acer Aspire V5-473P-5602 Motherboard Replacement: adım 3, 1 resimden 1.
    • Unplug the battery from the motherboard.
  4. Acer Aspire V5-473P-5602 Motherboard Replacement: adım 4, 1 resimden 1.
    • Carefully take the battery out of the device.
  5. Acer Aspire V5-473P-5602 Motherboard Replacement, Hard Drive: adım 5, 1 resimden 1.
    • Remove the four Phillips #0 screws from the hard drive.
  6. Acer Aspire V5-473P-5602 Motherboard Replacement: adım 6, 1 resimden 1.
    • Gently unplug the hard drive connector.
  7. Acer Aspire V5-473P-5602 Motherboard Replacement: adım 7, 1 resimden 1.
    • Remove the hard drive from the laptop.
  8. Acer Aspire V5-473P-5602 Motherboard Replacement, Fan: adım 8, 2 resimden 1. Acer Aspire V5-473P-5602 Motherboard Replacement, Fan: adım 8, 2 resimden 2.
    • Remove the five Phillips #0 screws that are holding the fan down to the base.
  9. Acer Aspire V5-473P-5602 Motherboard Replacement: adım 9, 2 resimden 1. Acer Aspire V5-473P-5602 Motherboard Replacement: adım 9, 2 resimden 2.
    • Gently unplug the cables from the Wi-Fi card.
  10. Acer Aspire V5-473P-5602 Motherboard Replacement: adım 10, 1 resimden 1.
    • Remove the fan from the laptop.
  11. Acer Aspire V5-473P-5602 Motherboard Replacement, Secondary Cooling Fan: adım 11, 2 resimden 1. Acer Aspire V5-473P-5602 Motherboard Replacement, Secondary Cooling Fan: adım 11, 2 resimden 2.
    • Unplug the cable that connects to the fan to motherboard.
  12. Acer Aspire V5-473P-5602 Motherboard Replacement: adım 12, 1 resimden 1.
    • Remove the two Phillips #0 screws that secure the fan to the base.
  13. Acer Aspire V5-473P-5602 Motherboard Replacement, Motherboard: adım 13, 2 resimden 1. Acer Aspire V5-473P-5602 Motherboard Replacement, Motherboard: adım 13, 2 resimden 2.
    • Remove the ten Phillips #0 screws that attach the motherboard to the keyboard.
  14. Acer Aspire V5-473P-5602 Motherboard Replacement: adım 14, 3 resimden 1. Acer Aspire V5-473P-5602 Motherboard Replacement: adım 14, 3 resimden 2. Acer Aspire V5-473P-5602 Motherboard Replacement: adım 14, 3 resimden 3.
    • Unplug the two data cables that attach the keyboard to the motherboard.
    • Remove the motherboard from the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kristen Gismondi
81.231 İtibar
200 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
136 Üyeler
16.578 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 821
