Ana içeriğe geç
Acer Aspire V5-473P-5602 Touchpad Replacement
Neye ihtiyacın var
  1. Acer Aspire V5-473P-5602 Touchpad Replacement, Back Panel: adım 1, 2 resimden 1. Acer Aspire V5-473P-5602 Touchpad Replacement, Back Panel: adım 1, 2 resimden 2.
    • Flip the laptop over so the back panel is facing upwards.
    • Use the Phillips #0 screwdriver to remove seventeen 2.5mm screws.
    • Remove the back panel from the laptop using an iFixit opening tool.
  2. Acer Aspire V5-473P-5602 Touchpad Replacement, Battery: adım 2, 2 resimden 1. Acer Aspire V5-473P-5602 Touchpad Replacement, Battery: adım 2, 2 resimden 2.
    • Remove the Phillips #0 screw from the middle of the battery.
  3. Acer Aspire V5-473P-5602 Touchpad Replacement: adım 3, 1 resimden 1.
    • Unplug the battery from the motherboard.
  4. Acer Aspire V5-473P-5602 Touchpad Replacement: adım 4, 1 resimden 1.
    • Carefully take the battery out of the device.
  5. Acer Aspire V5-473P-5602 Touchpad Replacement, Touchpad: adım 5, 1 resimden 1.
    • Use a spudger to remove the aluminum foil tape from the touchpad.
  6. Acer Aspire V5-473P-5602 Touchpad Replacement: adım 6, 1 resimden 1.
    • Unplug the cable from the touchpad.
  7. Acer Aspire V5-473P-5602 Touchpad Replacement: adım 7, 1 resimden 1.
    • Remove ten Phillips #0 screws securing the touchpad to the base.
  8. Acer Aspire V5-473P-5602 Touchpad Replacement: adım 8, 1 resimden 1.
    • Use the pointed end of a spudger to remove the small triangular metal piece.
  9. Acer Aspire V5-473P-5602 Touchpad Replacement: adım 9, 2 resimden 1. Acer Aspire V5-473P-5602 Touchpad Replacement: adım 9, 2 resimden 2.
    • Use the spudger to lift up the touchpad carefully.
    • Remember to use electronic cleaner to clean the touchpad screen surface before placing the new touchpad back in.
Sonuç
Thuy Tran
267 İtibar
2 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 310
