Ana içeriğe geç
Acer Aspire V5-552PG-X469 Battery Replacement
Neye ihtiyacın var
  1. Acer Aspire V5-552PG-X469 Battery Replacement, Back Case: adım 1, 1 resimden 1.
    • Remove the storage tray on the left edge of the device.
  2. Acer Aspire V5-552PG-X469 Battery Replacement: adım 2, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove seventeen 7mm screws from the lower case.
  3. Acer Aspire V5-552PG-X469 Battery Replacement: adım 3, 1 resimden 1.
    • Lift up the back case to remove it.
  4. Acer Aspire V5-552PG-X469 Battery Replacement, Battery: adım 4, 2 resimden 1. Acer Aspire V5-552PG-X469 Battery Replacement, Battery: adım 4, 2 resimden 2.
    • Pull the battery connector away from the hard drive to disconnect it from its socket.
  5. Acer Aspire V5-552PG-X469 Battery Replacement: adım 5, 3 resimden 1. Acer Aspire V5-552PG-X469 Battery Replacement: adım 5, 3 resimden 2. Acer Aspire V5-552PG-X469 Battery Replacement: adım 5, 3 resimden 3.
    • Pull the white connector toward the battery to disconnect it.
    • Pull the black tape-wrapped connector toward the battery to disconnect it.
  6. Acer Aspire V5-552PG-X469 Battery Replacement: adım 6, 2 resimden 1. Acer Aspire V5-552PG-X469 Battery Replacement: adım 6, 2 resimden 2.
    • Remove the PH #0 screw from the center of the battery.
  7. Acer Aspire V5-552PG-X469 Battery Replacement: adım 7, 2 resimden 1. Acer Aspire V5-552PG-X469 Battery Replacement: adım 7, 2 resimden 2.
    • Lift up the battery to remove it.
    • Be careful not to bend the battery while lifting it out, as this may cause a fire hazard.
Sonuç
Rebecca Aseo
304 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 17
Her zaman: 1,255
