Ana içeriğe geç
Acer Aspire V5-571 CMOS / Bios Battery Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Acer Aspire V5-571 CMOS / Bios Battery Replacement, Keyboard: adım 1, 3 resimden 1. Acer Aspire V5-571 CMOS / Bios Battery Replacement, Keyboard: adım 1, 3 resimden 2. Acer Aspire V5-571 CMOS / Bios Battery Replacement, Keyboard: adım 1, 3 resimden 3.
    • Turn off the laptop and remove the battery.
    • Remove two screws securing the Keyboard.
    • The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
  2. Acer Aspire V5-571 CMOS / Bios Battery Replacement: adım 2, 3 resimden 1. Acer Aspire V5-571 CMOS / Bios Battery Replacement: adım 2, 3 resimden 2. Acer Aspire V5-571 CMOS / Bios Battery Replacement: adım 2, 3 resimden 3.
  3. Acer Aspire V5-571 CMOS / Bios Battery Replacement, Optical Drive: adım 3, 3 resimden 1. Acer Aspire V5-571 CMOS / Bios Battery Replacement, Optical Drive: adım 3, 3 resimden 2. Acer Aspire V5-571 CMOS / Bios Battery Replacement, Optical Drive: adım 3, 3 resimden 3.
    • Remove the screw securing the Optical drive and gently press the drive to show slightly as at the second pic.
    • Slide the drive to the left and remove it.
  4. Acer Aspire V5-571 CMOS / Bios Battery Replacement, Upper  Cover: adım 4, 3 resimden 1. Acer Aspire V5-571 CMOS / Bios Battery Replacement, Upper  Cover: adım 4, 3 resimden 2. Acer Aspire V5-571 CMOS / Bios Battery Replacement, Upper  Cover: adım 4, 3 resimden 3.
    • Remove 4x phillips screws and disconnect:
    • Power On button flex cable
    • Touch pad flex cable
    • Remove 18x Phillips screws from the bottom cover.
    • Remove any memory SD Card from the Card reader.
    • Start opening with a plastic opening tool.
  5. Acer Aspire V5-571 CMOS / Bios Battery Replacement: adım 5, 3 resimden 1. Acer Aspire V5-571 CMOS / Bios Battery Replacement: adım 5, 3 resimden 2. Acer Aspire V5-571 CMOS / Bios Battery Replacement: adım 5, 3 resimden 3.
    • Carefully separate the upper cover and remove it.
  6. Acer Aspire V5-571 CMOS / Bios Battery Replacement, HDD (Hard Disk Drive): adım 6, 3 resimden 1. Acer Aspire V5-571 CMOS / Bios Battery Replacement, HDD (Hard Disk Drive): adım 6, 3 resimden 2. Acer Aspire V5-571 CMOS / Bios Battery Replacement, HDD (Hard Disk Drive): adım 6, 3 resimden 3.
  7. Acer Aspire V5-571 CMOS / Bios Battery Replacement, Wi-Fi Half Mini PCIe card: adım 7, 2 resimden 1. Acer Aspire V5-571 CMOS / Bios Battery Replacement, Wi-Fi Half Mini PCIe card: adım 7, 2 resimden 2.
    • Remove one Phillips screw, securing th WLan card and disconnect the two coaxial antenna cables.
    • Remove the Wi-Fi card.
  8. Acer Aspire V5-571 CMOS / Bios Battery Replacement, Mother Board: adım 8, 3 resimden 1. Acer Aspire V5-571 CMOS / Bios Battery Replacement, Mother Board: adım 8, 3 resimden 2. Acer Aspire V5-571 CMOS / Bios Battery Replacement, Mother Board: adım 8, 3 resimden 3.
    • Remove the Memory Cover.
    • Disconnect the Loudspeaker cable connector.
  9. Acer Aspire V5-571 CMOS / Bios Battery Replacement: adım 9, 3 resimden 1. Acer Aspire V5-571 CMOS / Bios Battery Replacement: adım 9, 3 resimden 2. Acer Aspire V5-571 CMOS / Bios Battery Replacement: adım 9, 3 resimden 3.
    • Remove two Phillips screw from the Mother board and from the Optical drive SATA adapter.
    • Disconnect the LCD Display flex cable.
    • Disconnect the DC Jack cable.
    • Carefully remove the Optical drive SATA adapter.
    • We will disconnect the battery cable when we pick up the board.
  10. Acer Aspire V5-571 CMOS / Bios Battery Replacement: adım 10, 3 resimden 1. Acer Aspire V5-571 CMOS / Bios Battery Replacement: adım 10, 3 resimden 2. Acer Aspire V5-571 CMOS / Bios Battery Replacement: adım 10, 3 resimden 3.
    • Carefully pick up the Mother board and disconnect the Battery cable.
  11. Acer Aspire V5-571 CMOS / Bios Battery Replacement, CMOS / BIOS Battery: adım 11, 3 resimden 1. Acer Aspire V5-571 CMOS / Bios Battery Replacement, CMOS / BIOS Battery: adım 11, 3 resimden 2. Acer Aspire V5-571 CMOS / Bios Battery Replacement, CMOS / BIOS Battery: adım 11, 3 resimden 3.
    • Use sharp plastic tool and remove the CMOS Battery.
    • CR2032 - button cell lithium battery rated at 3.0 volts.
    • Did you do it successfully?
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
ZFix
191.882 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
321 Üyeler
1.516 adet Kılavuz yazıldı
7 Yorum
I need assistance with the G2201 Hardware Gap, Im attempting to remove a HHD password for a customers machine on this same model
chemanemelton - Yanıt
I have same problem with same mother board please help me
Mohammad Osman -
Hi. Thanks a lot. I manage to remove the CMOS battery, and I kept the laptop pc idle without the battery for nearly 7hrs. But still, when connected, I am asked for password/unlock key. Could you please help me how to discharge the CMOS.
amantaj - Yanıt
Hi.
Thanks so much.
I manage to remove the CMOS battery, and I kept the laptop pc idle without the battery for nearly 3hrs.
Omit Z - Yanıt
Please help me.
Omit Z - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 40
Son 30 gün: 175
Her zaman: 34,033
