Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
How to disassemble the laptop, clean or replace the Cooling system or the Fan and change CPU Thermal Compound / Grease. This will help you if your system overheads or switch off randomly.
____________________________________________________________________________
Neye ihtiyacın var
Videoya Genel Bakış
Turn off the laptop and remove the battery.
Remove two screws securing the Keyboard.
The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
Remove the screw securing the Optical drive and gently press the drive to show slightly as at the second pic.
Slide the drive to the left and remove it.
Remove 4x phillips screws and disconnect:
Power On button flex cable
Touch pad flex cable
Remove 18x Phillips screws from the bottom cover.
Remove any memory SD Card from the Card reader.
Start opening with a plastic opening tool.
Gently remove the HDD and disconnect the SATA cable from it.
Remove one Phillips screw, securing th WLan card and disconnect the two coaxial antenna cables.
Remove the Wi-Fi card.
Disconnect the Fan cable.
Unscrew the screws that hold the Cooling system to the Mother board.
Carefully lift the Cooling system right up.
4 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Hello!
Is ist possible to installa SSD storage to the V5-571G without removing the SATA?
Thanks for your reply
