Ana içeriğe geç
Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement, Keyboard: adım 1, 3 resimden 1. Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement, Keyboard: adım 1, 3 resimden 2. Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement, Keyboard: adım 1, 3 resimden 3.
    • Turn off the laptop and remove the battery.
    • Remove two screws securing the Keyboard.
    • The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
  2. Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement: adım 2, 3 resimden 1. Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement: adım 2, 3 resimden 2. Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement: adım 2, 3 resimden 3.
  3. Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement, Upper  Cover: adım 3, 3 resimden 1. Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement, Upper  Cover: adım 3, 3 resimden 2. Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement, Upper  Cover: adım 3, 3 resimden 3.
    • Remove 4x phillips screws and disconnect:
    • Power On button flex cable
    • Touch pad flex cable
    • Remove 18x Phillips screws from the bottom cover.
    • Remove any memory SD Card from the Card reader.
    • Start opening with a plastic opening tool.
  4. Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement: adım 4, 3 resimden 1. Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement: adım 4, 3 resimden 2. Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement: adım 4, 3 resimden 3.
    • Carefully separate the upper cover and remove it.
  5. Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement, HDD (Hard Disk Drive): adım 5, 3 resimden 1. Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement, HDD (Hard Disk Drive): adım 5, 3 resimden 2. Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement, HDD (Hard Disk Drive): adım 5, 3 resimden 3.
Sonuç
32 farklı kişi bu kılavuzu tamamladı.
ZFix
191.278 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.528 adet Kılavuz yazıldı
6 Yorum
Good job! What a pain, though, to swap the HDD :)
Steve Wojciechowski - Yanıt
I am currently working on this laptop and it doesn't open at all like this one. This is only one back... and 18 screws holding it on. I can partially snap the back off but i can't pry it apart by the dvd drive. I'm also guessing the same model is manufactured differently for different retailers. (This happens in the retail hardware world where a dewalt drill from home depot will be made cheaper than a dewalt from ace hardware) so now I"m stuck. any ideas would be helpful. thanks.
FallenAnjel - Yanıt
ok found the problem. i accidentally popped out the dvd drive (when I was just trying to open it lol) and up under the lip I found three 1/8" long very-flat head screws. unscrewed those and the back came right off.
FallenAnjel - Yanıt
New customer that does like shopping local with recommended proprietors and stockiest of the required components.
Thank you Mr Jason Paul Cominelli.
Jason Paul Cominelli - Yanıt
are 9mm hard disk can fit?
the original was 7mm
jason.chiah1008 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 82
Her zaman: 69,521
