Ana içeriğe geç
Acer Aspire V5-571 Loudspeakers Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Acer Aspire V5-571 Loudspeakers Replacement, Keyboard: adım 1, 3 resimden 1. Acer Aspire V5-571 Loudspeakers Replacement, Keyboard: adım 1, 3 resimden 2. Acer Aspire V5-571 Loudspeakers Replacement, Keyboard: adım 1, 3 resimden 3.
    • Turn off the laptop and remove the battery.
    • Remove two screws securing the Keyboard.
    • The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
  2. Acer Aspire V5-571 Loudspeakers Replacement: adım 2, 3 resimden 1. Acer Aspire V5-571 Loudspeakers Replacement: adım 2, 3 resimden 2. Acer Aspire V5-571 Loudspeakers Replacement: adım 2, 3 resimden 3.
  3. Acer Aspire V5-571 Loudspeakers Replacement, Optical Drive: adım 3, 3 resimden 1. Acer Aspire V5-571 Loudspeakers Replacement, Optical Drive: adım 3, 3 resimden 2. Acer Aspire V5-571 Loudspeakers Replacement, Optical Drive: adım 3, 3 resimden 3.
    • Remove the screw securing the Optical drive and gently press the drive to show slightly as at the second pic.
    • Slide the drive to the left and remove it.
  4. Acer Aspire V5-571 Loudspeakers Replacement, Upper  Cover: adım 4, 3 resimden 1. Acer Aspire V5-571 Loudspeakers Replacement, Upper  Cover: adım 4, 3 resimden 2. Acer Aspire V5-571 Loudspeakers Replacement, Upper  Cover: adım 4, 3 resimden 3.
    • Remove 4x phillips screws and disconnect:
    • Power On button flex cable
    • Touch pad flex cable
    • Remove 18x Phillips screws from the bottom cover.
    • Remove any memory SD Card from the Card reader.
    • Start opening with a plastic opening tool.
  5. Acer Aspire V5-571 Loudspeakers Replacement: adım 5, 3 resimden 1. Acer Aspire V5-571 Loudspeakers Replacement: adım 5, 3 resimden 2. Acer Aspire V5-571 Loudspeakers Replacement: adım 5, 3 resimden 3.
    • Carefully separate the upper cover and remove it.
  6. Acer Aspire V5-571 Loudspeakers Replacement, HDD (Hard Disk Drive): adım 6, 3 resimden 1. Acer Aspire V5-571 Loudspeakers Replacement, HDD (Hard Disk Drive): adım 6, 3 resimden 2. Acer Aspire V5-571 Loudspeakers Replacement, HDD (Hard Disk Drive): adım 6, 3 resimden 3.
  7. Acer Aspire V5-571 Loudspeakers Replacement, Wi-Fi Half Mini PCIe card: adım 7, 2 resimden 1. Acer Aspire V5-571 Loudspeakers Replacement, Wi-Fi Half Mini PCIe card: adım 7, 2 resimden 2.
    • Remove one Phillips screw, securing th WLan card and disconnect the two coaxial antenna cables.
    • Remove the Wi-Fi card.
  8. Acer Aspire V5-571 Loudspeakers Replacement, Mother Board: adım 8, 3 resimden 1. Acer Aspire V5-571 Loudspeakers Replacement, Mother Board: adım 8, 3 resimden 2. Acer Aspire V5-571 Loudspeakers Replacement, Mother Board: adım 8, 3 resimden 3.
    • Remove the Memory Cover.
    • Disconnect the Loudspeaker cable connector.
  9. Acer Aspire V5-571 Loudspeakers Replacement: adım 9, 3 resimden 1. Acer Aspire V5-571 Loudspeakers Replacement: adım 9, 3 resimden 2. Acer Aspire V5-571 Loudspeakers Replacement: adım 9, 3 resimden 3.
    • Remove two Phillips screw from the Mother board and from the Optical drive SATA adapter.
    • Disconnect the LCD Display flex cable.
    • Disconnect the DC Jack cable.
    • Carefully remove the Optical drive SATA adapter.
    • We will disconnect the battery cable when we pick up the board.
  10. Acer Aspire V5-571 Loudspeakers Replacement: adım 10, 3 resimden 1. Acer Aspire V5-571 Loudspeakers Replacement: adım 10, 3 resimden 2. Acer Aspire V5-571 Loudspeakers Replacement: adım 10, 3 resimden 3.
    • Carefully pick up the Mother board and disconnect the Battery cable.
  11. Acer Aspire V5-571 Loudspeakers Replacement, Loudspeakers: adım 11, 2 resimden 1. Acer Aspire V5-571 Loudspeakers Replacement, Loudspeakers: adım 11, 2 resimden 2.
    • There are two Loudspeakers. Each of them is held by two Phillips screws.
    • Did you do it successfully?
Sonuç
ZFix
194.222 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
327 Üyeler
1.673 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 1,744
