Ana içeriğe geç
Acer Aspire V5-571 Optical Drive Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Acer Aspire V5-571 Optical Drive Replacement, Keyboard: adım 1, 3 resimden 1. Acer Aspire V5-571 Optical Drive Replacement, Keyboard: adım 1, 3 resimden 2. Acer Aspire V5-571 Optical Drive Replacement, Keyboard: adım 1, 3 resimden 3.
    • Turn off the laptop and remove the battery.
    • Remove two screws securing the Keyboard.
    • The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
    The two clips push toward the space-bar part of the keyboard. There are further clips around the edge of the keyboard, but it can be removed by careful prying with a thin blade screwdriver.
    ENT - Yanıt
  2. Acer Aspire V5-571 Optical Drive Replacement: adım 2, 3 resimden 1. Acer Aspire V5-571 Optical Drive Replacement: adım 2, 3 resimden 2. Acer Aspire V5-571 Optical Drive Replacement: adım 2, 3 resimden 3.
    It would be helpful to have more info on how to remove the two cables. The larger one has a couple of clips that slide, but what exactly comes off? Do the plastic strips lift, or do the flat cables just pull out of them? Don't want to break something!
    ENT - Yanıt
    I watched several videos, many of which had the action hidden behind the keyboard. The larger ribbon pulls out of the strip after the two white clips on the end are moved. The smaller one has a black strip which lifts from the ribbon side, releasing the cable.
    ENT - Yanıt
  3. Acer Aspire V5-571 Optical Drive Replacement, Optical Drive: adım 3, 3 resimden 1. Acer Aspire V5-571 Optical Drive Replacement, Optical Drive: adım 3, 3 resimden 2. Acer Aspire V5-571 Optical Drive Replacement, Optical Drive: adım 3, 3 resimden 3.
    • Remove the screw securing the Optical drive and gently press the drive to show slightly as at the second pic.
    • Slide the drive to the left and remove it.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
ZFix
194.147 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
326 Üyeler
1.672 adet Kılavuz yazıldı
2Kılavuz Yorumları
Is it safe to use with the optical drive out? I just took it out and I don't get the part until next week but I need to use my laptop... can I use it?
I needed to replace it because I dropped my laptop off the arm of the sofa with the drive open and falling on that side too.
Vianca - Yanıt
Is it safe to use the laptop with the optical drive out?
Vianca - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 21
Her zaman: 5,209
