Ana içeriğe geç
Acer Aspire V5-571 Upper Cover Replacement
Neye ihtiyacın var
  1. Acer Aspire V5-571 Upper  Cover Replacement, Keyboard: adım 1, 3 resimden 1. Acer Aspire V5-571 Upper  Cover Replacement, Keyboard: adım 1, 3 resimden 2. Acer Aspire V5-571 Upper  Cover Replacement, Keyboard: adım 1, 3 resimden 3.
    • Turn off the laptop and remove the battery.
    • Remove two screws securing the Keyboard.
    • The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
  2. Acer Aspire V5-571 Upper  Cover Replacement: adım 2, 3 resimden 1. Acer Aspire V5-571 Upper  Cover Replacement: adım 2, 3 resimden 2. Acer Aspire V5-571 Upper  Cover Replacement: adım 2, 3 resimden 3.
  3. Acer Aspire V5-571 Upper  Cover Replacement, Optical Drive: adım 3, 3 resimden 1. Acer Aspire V5-571 Upper  Cover Replacement, Optical Drive: adım 3, 3 resimden 2. Acer Aspire V5-571 Upper  Cover Replacement, Optical Drive: adım 3, 3 resimden 3.
    • Remove the screw securing the Optical drive and gently press the drive to show slightly as at the second pic.
    • Slide the drive to the left and remove it.
  4. Acer Aspire V5-571 Upper  Cover Replacement, Upper  Cover: adım 4, 3 resimden 1. Acer Aspire V5-571 Upper  Cover Replacement, Upper  Cover: adım 4, 3 resimden 2. Acer Aspire V5-571 Upper  Cover Replacement, Upper  Cover: adım 4, 3 resimden 3.
    • Remove 4x phillips screws and disconnect:
    • Power On button flex cable
    • Touch pad flex cable
    • Remove 18x Phillips screws from the bottom cover.
    • Remove any memory SD Card from the Card reader.
    • Start opening with a plastic opening tool.
  5. Acer Aspire V5-571 Upper  Cover Replacement: adım 5, 3 resimden 1. Acer Aspire V5-571 Upper  Cover Replacement: adım 5, 3 resimden 2. Acer Aspire V5-571 Upper  Cover Replacement: adım 5, 3 resimden 3.
    • Carefully separate the upper cover and remove it.
Sonuç
ZFix
194.222 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
327 Üyeler
1.673 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 20
Her zaman: 3,136
