Ana içeriğe geç
Acer Aspire V5-571 Wi-Fi Half Mini PCIe card Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Acer Aspire V5-571 Wi-Fi Half Mini PCIe card Replacement, Keyboard: adım 1, 3 resimden 1. Acer Aspire V5-571 Wi-Fi Half Mini PCIe card Replacement, Keyboard: adım 1, 3 resimden 2. Acer Aspire V5-571 Wi-Fi Half Mini PCIe card Replacement, Keyboard: adım 1, 3 resimden 3.
    • Turn off the laptop and remove the battery.
    • Remove two screws securing the Keyboard.
    • The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
  2. Acer Aspire V5-571 Wi-Fi Half Mini PCIe card Replacement: adım 2, 3 resimden 1. Acer Aspire V5-571 Wi-Fi Half Mini PCIe card Replacement: adım 2, 3 resimden 2. Acer Aspire V5-571 Wi-Fi Half Mini PCIe card Replacement: adım 2, 3 resimden 3.
  3. Acer Aspire V5-571 Wi-Fi Half Mini PCIe card Replacement, Upper  Cover: adım 3, 3 resimden 1. Acer Aspire V5-571 Wi-Fi Half Mini PCIe card Replacement, Upper  Cover: adım 3, 3 resimden 2. Acer Aspire V5-571 Wi-Fi Half Mini PCIe card Replacement, Upper  Cover: adım 3, 3 resimden 3.
    • Remove 4x phillips screws and disconnect:
    • Power On button flex cable
    • Touch pad flex cable
    • Remove 18x Phillips screws from the bottom cover.
    • Remove any memory SD Card from the Card reader.
    • Start opening with a plastic opening tool.
  4. Acer Aspire V5-571 Wi-Fi Half Mini PCIe card Replacement: adım 4, 3 resimden 1. Acer Aspire V5-571 Wi-Fi Half Mini PCIe card Replacement: adım 4, 3 resimden 2. Acer Aspire V5-571 Wi-Fi Half Mini PCIe card Replacement: adım 4, 3 resimden 3.
    • Carefully separate the upper cover and remove it.
  5. Acer Aspire V5-571 Wi-Fi Half Mini PCIe card Replacement, Wi-Fi Half Mini PCIe card: adım 5, 2 resimden 1. Acer Aspire V5-571 Wi-Fi Half Mini PCIe card Replacement, Wi-Fi Half Mini PCIe card: adım 5, 2 resimden 2.
    • Remove one Phillips screw, securing th WLan card and disconnect the two coaxial antenna cables.
    • Remove the Wi-Fi card.
Sonuç
ZFix
194.093 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
327 Üyeler
1.699 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 5
Son 30 gün: 13
Her zaman: 2,871
