Ana içeriğe geç
Acer Aspire V5-571-6889 Hard Drive Replacement
Neye ihtiyacın var
  1. Acer Aspire V5-571-6889 Hard Drive Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Flip laptop over so that the back is facing upward.
    • Push switch to the right.
    • Pull battery away from the laptop.
  2. Acer Aspire V5-571-6889 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Use a #0 Phillips head screw driver to remove all of the screws.
  3. Acer Aspire V5-571-6889 Hard Drive Replacement: adım 3, 1 resimden 1.
    • Flip laptop back over.
    • Open the laptop.
    • Wedge a prying tool between the keyboard and laptop body seam to remove keyboard.
    • Be careful not to bend the keyboard too much or break the tabs that connect the keyboard to the laptop.
  4. Acer Aspire V5-571-6889 Hard Drive Replacement: adım 4, 1 resimden 1.
    • Gently lift keyboard.
    • Disconnect keyboard from the laptop.
  5. Acer Aspire V5-571-6889 Hard Drive Replacement, Remove Upper Cover: adım 5, 1 resimden 1.
    • Disconnect the two ribbon cables at the near left.
    • Remove six screws: ⁃ one by the left most ribbon cable connector ⁃ one mid-right center ⁃ one on the near edge left of center ⁃ three across the back
    • Use a prying tool to remove the upper cover.
  6. Acer Aspire V5-571-6889 Hard Drive Replacement: adım 6, 1 resimden 1.
    • Locate the hard drive.
    • Lift the hard drive.
    • Disconnect hard drive.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Joe Niu
628 İtibar
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 15
Her zaman: 635
