Ana içeriğe geç
Acer Aspire V5-571-6891 Keyboard Replacement
Neye ihtiyacın var
  1. Acer Aspire V5-571-6891 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Use the pointed end of the spudger to slide the battery lock until the battery pops loose.
  2. Acer Aspire V5-571-6891 Keyboard Replacement: adım 2, 2 resimden 1. Acer Aspire V5-571-6891 Keyboard Replacement: adım 2, 2 resimden 2.
    • Slide the battery out of the battery slot.
  3. Acer Aspire V5-571-6891 Keyboard Replacement, Keyboard: adım 3, 1 resimden 1.
    • Remove the two 6mm PH1 screws from the bottom of the laptop.
  4. Acer Aspire V5-571-6891 Keyboard Replacement: adım 4, 1 resimden 1.
    • Use the spudger, push the two tabs, located in the battery slot, through their slots to release the keyboard.
    • Do this with the computer slightly open for ease.
  5. Acer Aspire V5-571-6891 Keyboard Replacement: adım 5, 2 resimden 1. Acer Aspire V5-571-6891 Keyboard Replacement: adım 5, 2 resimden 2.
    • Open the laptop.
    • Start top of the keyboard and use the opening tool to pop the remaining tabs around the keyboard loose.
    • The keyboard can be flipped onto its face once removed.
  6. Acer Aspire V5-571-6891 Keyboard Replacement: adım 6, 1 resimden 1.
    • Use the spudger and slide the grey tabs on either side of the keyboard wires away from the white plastic.
  7. Acer Aspire V5-571-6891 Keyboard Replacement: adım 7, 1 resimden 1.
    • Disconnect the keyboard by pulling the blue tape on the wire strip.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 23
Her zaman: 695
