Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Use the pointed end of the spudger to slide the battery lock until the battery pops loose.
Remove the two 6mm PH1 screws from the bottom of the laptop.
Use the spudger, push the two tabs, located in the battery slot, through their slots to release the keyboard.
Do this with the computer slightly open for ease.
Open the laptop.
Start top of the keyboard and use the opening tool to pop the remaining tabs around the keyboard loose.
The keyboard can be flipped onto its face once removed.
Use the spudger and slide the grey tabs on either side of the keyboard wires away from the white plastic.
Disconnect the keyboard by pulling the blue tape on the wire strip.
Bir başkası bu kılavuzu tamamladı.
