Ana içeriğe geç
Acer Aspire V5-571P-6815 Charging Port Replacement
Neye ihtiyacın var
  1. Acer Aspire V5-571P-6815 Charging Port Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off the computer and unplug all power.
  2. Acer Aspire V5-571P-6815 Charging Port Replacement: adım 2, 2 resimden 1. Acer Aspire V5-571P-6815 Charging Port Replacement: adım 2, 2 resimden 2.
    • Slide the locking latch to the right and hold while pulling the battery out with your other hand.
  3. Acer Aspire V5-571P-6815 Charging Port Replacement, Keyboard: adım 3, 1 resimden 1.
    • Remove the two 7mm Phillips #00 screws from the bottom of the laptop.
  4. Acer Aspire V5-571P-6815 Charging Port Replacement: adım 4, 3 resimden 1. Acer Aspire V5-571P-6815 Charging Port Replacement: adım 4, 3 resimden 2. Acer Aspire V5-571P-6815 Charging Port Replacement: adım 4, 3 resimden 3.
    • Insert a plastic opening tool underneath the keyboard and pry upwards.
    • Slide the plastic opening tool around the perimeter to free the keyboard.
    • Flip the keyboard over and onto the palm rest.
  5. Acer Aspire V5-571P-6815 Charging Port Replacement: adım 5, 3 resimden 1. Acer Aspire V5-571P-6815 Charging Port Replacement: adım 5, 3 resimden 2. Acer Aspire V5-571P-6815 Charging Port Replacement: adım 5, 3 resimden 3.
    • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Pull the ribbon cable out of the socket.
    • Remove the keyboard from the laptop.
  6. Acer Aspire V5-571P-6815 Charging Port Replacement, Charging Port: adım 6, 1 resimden 1.
    • Remove the six 6mm Phillips #0 screws from underneath the keyboard.
  7. Acer Aspire V5-571P-6815 Charging Port Replacement: adım 7, 1 resimden 1.
    • Remove the sixteen 6mm Phillips #0 screws from the bottom cover.
  8. Acer Aspire V5-571P-6815 Charging Port Replacement: adım 8, 3 resimden 1. Acer Aspire V5-571P-6815 Charging Port Replacement: adım 8, 3 resimden 2. Acer Aspire V5-571P-6815 Charging Port Replacement: adım 8, 3 resimden 3.
    • Use a spudger to flip up the retaining flap on the ribbon cable ZIF socket.
    • Pull the ribbon cable from the socket.
  9. Acer Aspire V5-571P-6815 Charging Port Replacement: adım 9, 2 resimden 1. Acer Aspire V5-571P-6815 Charging Port Replacement: adım 9, 2 resimden 2.
  10. Acer Aspire V5-571P-6815 Charging Port Replacement: adım 10, 3 resimden 1. Acer Aspire V5-571P-6815 Charging Port Replacement: adım 10, 3 resimden 2. Acer Aspire V5-571P-6815 Charging Port Replacement: adım 10, 3 resimden 3.
    • Use a plastic opening tool to pry up the palm rest from the laptop body.
    • Remove the palm rest from the laptop.
  11. Acer Aspire V5-571P-6815 Charging Port Replacement: adım 11, 2 resimden 1. Acer Aspire V5-571P-6815 Charging Port Replacement: adım 11, 2 resimden 2.
    • Disconnect the charging port cable from the motherboard.
    • You might have to remove some electrical tape that is in the way.
  12. Acer Aspire V5-571P-6815 Charging Port Replacement: adım 12, 3 resimden 1. Acer Aspire V5-571P-6815 Charging Port Replacement: adım 12, 3 resimden 2. Acer Aspire V5-571P-6815 Charging Port Replacement: adım 12, 3 resimden 3.
    • Lift the charging port up and out of the laptop.
Sonuç
Follow the steps in reverse with a new cable.
Bir başkası bu kılavuzu tamamladı.
Gordon Tran
225 İtibar
1 Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G4, Liner Spring 2018 UW Tacoma, Team S1-G4, Liner Spring 2018 üyesi
UWT-LINER-S18S1G4
5 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 25
Her zaman: 5,509
