Ana içeriğe geç
Acer Aspire V5-572 - Battery Reset Pinhole
Neye ihtiyacın var
  1. Acer Aspire V5-572 - Battery Reset Pinhole, Acer Aspire V5-572 - Battery Reset Pinhole: adım 1, 3 resimden 1. Acer Aspire V5-572 - Battery Reset Pinhole, Acer Aspire V5-572 - Battery Reset Pinhole: adım 1, 3 resimden 2. Acer Aspire V5-572 - Battery Reset Pinhole, Acer Aspire V5-572 - Battery Reset Pinhole: adım 1, 3 resimden 3.
    • At the bottom side of the laptop, you will find a small pinhole.
    • Insert a paperclip into the hole and press for four seconds to reset the computer.
Sonuç
34 farklı kişi bu kılavuzu tamamladı.
ZFix
194.093 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
327 Üyeler
1.699 adet Kılavuz yazıldı
40 Yorum
Yep-it worked exactly as suggested. Sharp end of a small safety pin and bobs your uncle.
Thanks again. Was worried that it could be something worse.
Russ
dabblers2 - Yanıt
Its not working on my laptop Acer aspire S3.. I press it in 4 second but its not gonna work.
What can I do to fix it?
dongyul54 - Yanıt
For those whose laptops are not working for pressing it for 4 seconds ..please follow the steps that i had explained below because i chat with the acer care and they told me these steps which helps me to fixed my acer aspire 7
Step 1 :- remove charger from the laptop
Step 2:- press the power button for 30 seconds
Step 3:- press the pin hole button for 25 seconds with the help of a paper clip or sim ejector tool .
Step 4 :- plug in the charger in the laptop and let it charge for 1 hour after 1 hour power on the laptop .....and boom your laptop will start working .....this trick will 100% work as this fixed my laptop
Atul -
Ok, it works perfectly..., thank you to your suggest.
My Acer Aspire ES1-512-C08J, did not accept anythink from keyboard to input password at start of windows 10, but in Bios setup did it works.
No solutions to change keyboard, or reset bios to default configuration, but only when i pushed in the pinhole reset switch battery on back laptop, while laptop was on, and it immediatly drops down switch off, and when i restart laptop from normal push button power on, all works another time ok.....
Sorry for my bad english...
Vito Perrino - Yanıt
Should I perform these steps with the laptop turned on or turned off?
Ridhwaan Hassim - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 30
Son 7 gün: 187
Son 30 gün: 862
Her zaman: 208,119
