Ana içeriğe geç
Acer Aspire V5-572 Bottom Cover Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Acer Aspire V5-572 Bottom Cover Replacement, Bottom Cover: adım 1, 1 resimden 1.
    • Switch-off the Laptop.
    • Remove the seventeen Philips #0 screws.
  2. Acer Aspire V5-572 Bottom Cover Replacement: adım 2, 1 resimden 1.
    • If there is a plastic storage tray in the laptop, remove it.
  3. Acer Aspire V5-572 Bottom Cover Replacement: adım 3, 3 resimden 1. Acer Aspire V5-572 Bottom Cover Replacement: adım 3, 3 resimden 2. Acer Aspire V5-572 Bottom Cover Replacement: adım 3, 3 resimden 3.
    • Starting from the SD Memory Card hole, start prying between the top and bottom cases.
    • Use plastic tools to avoid damaging the cover.
    • Remove the bottom case.
    Love the tutorial man...but this is the most moronic thing I've ever seen...you can take batery out of laptop 15 years old in a flash, while here you have to disassemble the whole %#*@ laptop...only idiots can come up with something like that
    razbojnikkuro - Yanıt
    I have to agree that this is extremely complicated and intense.
    There is no way your average user should be doing this and the average user should be able to replace the battery!!
    Like everything in the computer world, hardware or software, ease of use is no longer even a consideration!!
    Technical Support Bots are the rule and they rarely are up to date with the pages on the website!!
    Sucks!!
    andy.cox - Yanıt
  4. Acer Aspire V5-572 Bottom Cover Replacement: adım 4, 1 resimden 1.
    • Disconnect the battery immediately for a safer repair.
    • Pull the battery connector away from the hard drive to disconnect it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
ZFix
191.308 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.534 adet Kılavuz yazıldı
Bir Yorum
Hello, I'm just trying to find this bottom casing -- anywhere -- and cannot seem to be able to find or purchase one. Often the wrong one comes up when I search (as evidenced by vents in the wrong places). Any ideas? Thanks in advance.
bellemcc - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 15
Her zaman: 3,855
