Ana içeriğe geç
Acer Aspire V5-572, V5-572G Battery Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Acer Aspire V5-572, V5-572G Battery Replacement, Bottom Cover: adım 1, 1 resimden 1.
    • Switch-off the Laptop.
    • Remove the seventeen Philips #0 screws.
  2. Acer Aspire V5-572, V5-572G Battery Replacement: adım 2, 1 resimden 1.
    • If there is a plastic storage tray in the laptop, remove it.
  3. Acer Aspire V5-572, V5-572G Battery Replacement: adım 3, 3 resimden 1. Acer Aspire V5-572, V5-572G Battery Replacement: adım 3, 3 resimden 2. Acer Aspire V5-572, V5-572G Battery Replacement: adım 3, 3 resimden 3.
    • Starting from the SD Memory Card hole, start prying between the top and bottom cases.
    • Use plastic tools to avoid damaging the cover.
    • Remove the bottom case.
  4. Acer Aspire V5-572, V5-572G Battery Replacement: adım 4, 1 resimden 1.
    • Disconnect the battery immediately for a safer repair.
    • Pull the battery connector away from the hard drive to disconnect it.
  5. Acer Aspire V5-572, V5-572G Battery Replacement, Battery: adım 5, 1 resimden 1.
    • Remove the single Phillips 0 screw securing the battery.
  6. Acer Aspire V5-572, V5-572G Battery Replacement: adım 6, 1 resimden 1.
    • Remove the battery
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
ZFix
191.278 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.528 adet Kılavuz yazıldı
Bir Yorum
I plugged a wrong charger on my acer aspire v5 15-572 now it dosent charge what could be the problem
Joseph Musariri - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 22
Her zaman: 15,610
