Ana içeriğe geç
Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement, Bottom Cover: adım 1, 1 resimden 1.
    • Switch-off the Laptop.
    • Remove the seventeen Philips #0 screws.
  2. Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement: adım 2, 1 resimden 1.
    • If there is a plastic storage tray in the laptop, remove it.
  3. Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement: adım 3, 3 resimden 1. Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement: adım 3, 3 resimden 2. Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement: adım 3, 3 resimden 3.
    • Starting from the SD Memory Card hole, start prying between the top and bottom cases.
    • Use plastic tools to avoid damaging the cover.
    • Remove the bottom case.
  4. Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement: adım 4, 1 resimden 1.
    • Disconnect the battery immediately for a safer repair.
    • Pull the battery connector away from the hard drive to disconnect it.
  5. Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement, Battery: adım 5, 1 resimden 1.
    • Remove the single Phillips 0 screw securing the battery.
  6. Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement: adım 6, 1 resimden 1.
    • Remove the battery
  7. Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement, Loudspeakers and Microphone: adım 7, 3 resimden 1. Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement, Loudspeakers and Microphone: adım 7, 3 resimden 2. Acer Aspire V5-572, V5-572G Loudspeakers and Microphone Replacement, Loudspeakers and Microphone: adım 7, 3 resimden 3.
    • Disconnect the Loudspeakers cable.
    • There are two modules with loudspeakers, connected with one wire.
    • Unscrew the screws and remove the Loudspeaker modules together with the cable.
Sonuç
Bir başkası bu kılavuzu tamamladı.
ZFix
191.055 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.506 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 39
Her zaman: 2,142
