Giriş
How to disassemble Acer Aspire - V5-572, V5-572G and remove the Main board.
Aletler
Parçalar
Hiçbir parça belirtilmedi.
Videoya Genel Bakış
Disconnect the SATA Cable from the Mother Board.
Take out the HDD and remove the SATA cable from it.
Now you can change / upgrade your HDD.
Remove 1x screw and disconnect the two antenna coaxial cables.
Remove the Wi-Fi card from the slot.
Disconnect the Fan cable.
Remove the three screws from the CPU cooler and one from the Fan module.
Disconnect one by one:
LCD Display flex cable
DC Jack cable
USB Board flex cable
Touch pad flex cable
Keyboard flex cable
Bir başkası bu kılavuzu tamamladı.
