Giriş
Acer Aspire - V5-572, V5-572G
We will show you how to open the Laptop and install a new RAM Module.
Videoya Genel Bakış
  1. Switch-off the Laptop. Remove 17x Philips screws.
    • Switch-off the Laptop.
    • Remove 17x Philips screws.
  2. Start opening from the SD Memory Card hole Use plastic tools to avoid damaging the cover. Use plastic tools to avoid damaging the cover.
    • Start opening from the SD Memory Card hole
    • Use plastic tools to avoid damaging the cover.
  3. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  4. Before doing anything, disconnect the battery.
    • Before doing anything, disconnect the battery.
  5. This model have 1x Memory Slot. You can upgrade your laptop with SODIMM DDR3 ram at 1333 or 1600. You can upgrade your laptop with SODIMM DDR3 ram at 1333 or 1600.
    • This model have 1x Memory Slot.
    • You can upgrade your laptop with SODIMM DDR3 ram at 1333 or 1600.
Sonuç
4 başka kişi bu kılavuzu tamamladı.
ZFix
162.332 İtibar
304 adet Kılavuz yazıldı
Takım
Master Techs Master Techs üyesi
Community
280 Üyeler
783 adet Kılavuz yazıldı
Bir Yorum
Hi,
While adding an extra RAM to the module in Aspire V5-472, I forgot to disconnnect the battery first.
I first tried 4 GB RAM compatible, SODIMMM- DDR3L 204-Pin Laptop Memory, Low Voltage. When that didn't work, I checked again.
Next time I disconnected the battery, and repeated the process with 2 GB RAM, compatible, SODIMMM- DDR3L 204-Pin Laptop Memory, Low Voltage. The RAM was still not discovered. None of the RAMs were detected.
Hope I haven't fried the RAM Module itself.
Please help.
Indi Shukla - Yanıt
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 Gün: 42
Son 30 Gün: 192
Her zaman: 13,716
