Ana içeriğe geç
Acer Aspire V5-572, V5-572G Wi-Fi half mini PCIe card Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Acer Aspire V5-572, V5-572G Wi-Fi half mini PCIe card Replacement, Bottom Cover: adım 1, 1 resimden 1.
    • Switch-off the Laptop.
    • Remove the seventeen Philips #0 screws.
  2. Acer Aspire V5-572, V5-572G Wi-Fi half mini PCIe card Replacement: adım 2, 1 resimden 1.
    • If there is a plastic storage tray in the laptop, remove it.
  3. Acer Aspire V5-572, V5-572G Wi-Fi half mini PCIe card Replacement: adım 3, 3 resimden 1. Acer Aspire V5-572, V5-572G Wi-Fi half mini PCIe card Replacement: adım 3, 3 resimden 2. Acer Aspire V5-572, V5-572G Wi-Fi half mini PCIe card Replacement: adım 3, 3 resimden 3.
    • Starting from the SD Memory Card hole, start prying between the top and bottom cases.
    • Use plastic tools to avoid damaging the cover.
    • Remove the bottom case.
  4. Acer Aspire V5-572, V5-572G Wi-Fi half mini PCIe card Replacement: adım 4, 1 resimden 1.
    • Disconnect the battery immediately for a safer repair.
    • Pull the battery connector away from the hard drive to disconnect it.
  5. Acer Aspire V5-572, V5-572G Wi-Fi half mini PCIe card Replacement, Wi-Fi half mini PCIe card: adım 5, 3 resimden 1. Acer Aspire V5-572, V5-572G Wi-Fi half mini PCIe card Replacement, Wi-Fi half mini PCIe card: adım 5, 3 resimden 2. Acer Aspire V5-572, V5-572G Wi-Fi half mini PCIe card Replacement, Wi-Fi half mini PCIe card: adım 5, 3 resimden 3.
    • Remove 1x screw and disconnect the two antenna coaxial cables.
    • Remove the Wi-Fi card from the slot.
Sonuç
ZFix
191.308 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.534 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 22
Her zaman: 4,481
