Giriş
Acer Aspire V5-591G-75KE is manufactured with a 6-cell Lithium Ion (Li-Ion) 5040 mAh laptop battery. Batteries in laptops are very specific in their shape and capacity, so make sure you obtain a suitable replacement for the Acer Aspire V5-591G-75KE.
Neye ihtiyacın var
Close down the display and flip the device upside down.
Use a Phillips #1 screwdriver to remove 18 black 10mm Phillips Head screws in order to loosen up the protective bottom casing.
The laptop battery is the black rectangular item at the top.
The battery connects to the motherboard via a multi-colored 8-pin connector.
Using a pair of blunt tweezers, push the white tabs on the sides 8-pin connector to disconnect the battery from the motherboard.
2 farklı kişi bu kılavuzu tamamladı.
