Ana içeriğe geç
Acer Aspire a515-46 SSD Replacement
Neye ihtiyacın var
  1. Acer Aspire a515-46 SSD Replacement, Turn off: adım 1, 1 resimden 1.
    • If laptop is not already off, hold power button for 5 seconds until screen shuts off.
    • If needed, backup any files to a USB or an external hard drive before turning off and replacing SSD.
  2. Acer Aspire a515-46 SSD Replacement, Remove Back Panel 1 of 3: adım 2, 1 resimden 1.
    • Flip the laptop over and locate the screws on the back panel.
  3. Acer Aspire a515-46 SSD Replacement, Remove Back Panel 2 of 3: adım 3, 3 resimden 1. Acer Aspire a515-46 SSD Replacement, Remove Back Panel 2 of 3: adım 3, 3 resimden 2. Acer Aspire a515-46 SSD Replacement, Remove Back Panel 2 of 3: adım 3, 3 resimden 3.
    • Using a Philips head screwdriver, remove all of the screws on the back panel.
  4. Acer Aspire a515-46 SSD Replacement, Remove Back Panel 3 of 3: adım 4, 3 resimden 1. Acer Aspire a515-46 SSD Replacement, Remove Back Panel 3 of 3: adım 4, 3 resimden 2. Acer Aspire a515-46 SSD Replacement, Remove Back Panel 3 of 3: adım 4, 3 resimden 3.
    • Use a small screwdriver or prybar to pry the back panel away from the laptop.
  5. Acer Aspire a515-46 SSD Replacement, Remove Battery 1 of 3: adım 5, 2 resimden 1. Acer Aspire a515-46 SSD Replacement, Remove Battery 1 of 3: adım 5, 2 resimden 2.
    • Remove the two pieces of tape holding the battery connector and wires.
  6. Acer Aspire a515-46 SSD Replacement, Remove Battery 2 of 3: adım 6, 3 resimden 1. Acer Aspire a515-46 SSD Replacement, Remove Battery 2 of 3: adım 6, 3 resimden 2. Acer Aspire a515-46 SSD Replacement, Remove Battery 2 of 3: adım 6, 3 resimden 3.
    • Using your fingernails, pinch the battery connector on both sides and pull it straight back until it is removed from the socket.
  7. Acer Aspire a515-46 SSD Replacement, Remove Battery 3 of 3: adım 7, 2 resimden 1. Acer Aspire a515-46 SSD Replacement, Remove Battery 3 of 3: adım 7, 2 resimden 2.
    • Pull up and remove the battery from the compartment.
  8. Acer Aspire a515-46 SSD Replacement, Replace SSD 1 of 3: adım 8, 2 resimden 1. Acer Aspire a515-46 SSD Replacement, Replace SSD 1 of 3: adım 8, 2 resimden 2.
    • Use a small Philips head screwdriver to remove the screw holding the bottom of the SSD.
  9. Acer Aspire a515-46 SSD Replacement, Replace SSD 2 of 3: adım 9, 2 resimden 1. Acer Aspire a515-46 SSD Replacement, Replace SSD 2 of 3: adım 9, 2 resimden 2.
    • Pull the SSD straight back until it is removed from the socket.
  10. Acer Aspire a515-46 SSD Replacement, Replace SSD 3 of 3: adım 10, 2 resimden 1. Acer Aspire a515-46 SSD Replacement, Replace SSD 3 of 3: adım 10, 2 resimden 2.
    • Insert the new SSD into the socket, making sure that the notch is on the right side of the SSD.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Am Persand
211 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 14
Her zaman: 533
