Neye ihtiyacın var
Close your Chromebook and flip it over on its back.
Remove the 12 screws holding on the back cover with a Philips #1 screwdriver.
Use a spudger or pry tool to release the clips and remove the back cover.
Carefully peel back the tape covering the battery and keyboard connectors.
Disconnect the two antenna cables by gently pulling up on them. (labeled "B")
Remove the screw holding down the wireless card. (labeled "C")
Carefully remove the card by pulling it out of its slot on the motherboard.
Position the new wireless card so that the white label is on top, and the connector is on the right.
Insert the wireless card into the connector on the motherboard at a 15-20 degree angle, then press down on the left side until it is flat.
Screw in the screw on the left side of the wireless card (labeled "C").
Attach the antennas as shown in the picture (white on the top and black on the bottom) by carefully snapping the connectors on using your fingernail or a spudger. (labeled "B")
Reconnect the battery to the motherboard by pushing the plug into its connector.
Congratulations! You just replaced your Chromebook's wireless card.
