Ana içeriğe geç
Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement
Neye ihtiyacın var
  1. Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement, Headphone Jack: adım 1, 3 resimden 1. Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement, Headphone Jack: adım 1, 3 resimden 2. Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement, Headphone Jack: adım 1, 3 resimden 3.
    • Use a Phillips #0 screwdriver to unscrew the eight 4mm screws.
    • Use a Phillips #0 screwdriver to unscrew the two 7mm screws.
    • iFixit's magnetic project mat is great for keeping the screws organized.
    • Remove the cover of the device by prying up from one of the edges with a spudger or plastic opening tool.
    • If the back cover is hard to remove, carefully use a metal spudger to remove the back cover.
  2. Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: adım 2, 3 resimden 1. Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: adım 2, 3 resimden 2. Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: adım 2, 3 resimden 3.
    • Use a spudger to disconnect the speaker connector from the bottom of the sound card. The connector should slide out toward the left speaker's housing.
    • Be sure to remove the connector evenly from the port.
  3. Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: adım 3, 2 resimden 1. Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: adım 3, 2 resimden 2.
    • Use a spudger to carefully disconnect the ribbon connector from the right side of the sound card. The connector should slide out toward the motherboard.
    • Be sure to remove the connector evenly from the port, as the ribbon connector may be fragile.
  4. Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: adım 4, 2 resimden 1. Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: adım 4, 2 resimden 2.
    • Use a Phillips #0 screwdriver to unscrew the two 4mm screws.
  5. Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: adım 5, 1 resimden 1.
    • Slide the sound card towards the motherboard until the headphone jack is out of its hole on the side of the laptop.
    • Lift the sound card directly up from the laptop to remove it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 602
