Ana içeriğe geç
Acer Chromebook 15 C910-C453 Battery Replacement
Neye ihtiyacın var
  1. Acer Chromebook 15 C910-C453 Battery Replacement, Battery: adım 1, 2 resimden 1. Acer Chromebook 15 C910-C453 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the Chromebook onto its backside and unscrew the the following Phillips #1 screws:
    • Sixteen 5mm Phillips screws located around the border.
    • Two 5mm Phillips screws located in center.
  2. Acer Chromebook 15 C910-C453 Battery Replacement: adım 2, 1 resimden 1.
    • Remove the back cover by carefully prying each side with an iFixit Opening Tool.
    • Set aside back cover.
  3. Acer Chromebook 15 C910-C453 Battery Replacement: adım 3, 2 resimden 1. Acer Chromebook 15 C910-C453 Battery Replacement: adım 3, 2 resimden 2.
    • Using a spudger, carefully unplug the rainbow wires connected to the top of the battery.
  4. Acer Chromebook 15 C910-C453 Battery Replacement: adım 4, 2 resimden 1. Acer Chromebook 15 C910-C453 Battery Replacement: adım 4, 2 resimden 2.
    • Unscrew the 4mm Phillips #1 screw located at the top right of battery.
  5. Acer Chromebook 15 C910-C453 Battery Replacement: adım 5, 1 resimden 1.
    • Remove the battery.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Jacob Rakestraw
419 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S15-G1, Banghart Spring 2017 Cal Poly, Team S15-G1, Banghart Spring 2017 üyesi
CPSU-BANGHART-S17S15G1
5 Üyeler
11 adet Kılavuz yazıldı
Bir Yorum
Jacob, WELL DONE. I have an Acer 15 C910-C451 that was driving me nuts. It would hold a battery charge but only up to 17% then drain fairly rapidly duing use. It didn’t make sense that a battery would have a set of bad cells but that is probably exactly what was the problem. So new battery in hand and a set of tools designed not to harm the case I followed your instructions to the letter. BINGO ! At this moment the unit is charging from a start of 87% it is now at 96% and climbing. Thanks for the detailed pics of the process.
Thomas Revell - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 26
Her zaman: 10,160
